Page 3 of 32 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 475
  1. #31
    Sep 2010
    Default clio3 old faulty and new replacement
    replacement_column.rarclio_faulty_column.rar old and replacement files in bin format sorry for the mistake any assistance will be much appreciated
  2. #32
    polska
    Hello,i have a Renault Modus 8200 433 517--D
    with DEF002 Fault
    eeprom 24c16
    Please can repaired the dump.
    Many thanks
  3. #33
    busaman's Avatar
    suffolk uk
    ok the fault DEF002 from what i understand is a software corruption on the ecu(no steering angle etc) but what causes it and what is to stop it happening again i have one here with that code the customer wants a new column but i would rather fix this there is no immo on 2005 modus/clio3 (it runs fine with out it)
    7.31sec@203.3mph
  4. #34
    Sep 2012
    Default D.A modus fault interne calculateur
    hello menbers i have a probleme with my modus fault calculateur interne pleaz repair my 24c16 with my immo
    Best D.K
    Attachment 219357
  5. #35
    Default Renault Modus Power Steering Def002
    Someone can help me to repair the file Renault Modus Power Steering, eeprom 24c16?
    8200 433 517--D
    Def002
    Thanks in advance
  6. #36
    Dec 2010
    Quote Originally Posted by CIRCUIT.FR View Post
    I post again your repared file:
    hello CIRCUIT.FR this file dont worck any more ,i try to use patrian softwere but is not possible can you please help me ... thanks
  7. #37
    Default Renault Modus 2007 8200 826 817--A
    Hello,i have a DAE modus 24C16 12 12 13.rar
    with DEF002 Fault
    eeprom 24lc16
    Many thanks
  8. #38
    Hello,i have a Renault Modus 2007 8200 826 817--A
    with DEF002 Fault
    eeprom 24lc16
    Many thanks
  9. #39
    DK Veteran kelekele's Avatar
    Sonta,Serbia
    Have modus 2004 1.2 with faulty power steering.Error code is def02.Is it possible repair?
    Thanx in advance!
    modus orig 24C16 def02.zip
  10. #40
    May 2013
    Default DAE MODUS
    dump ok, passe mp
  11. #41
    hi dell66
    Have
    modus 2007 1.2 with faulty power steering.Error code is def02.Is it possible repair?
    Thanx in advance!
  12. #42
    May 2013
    Default DAE MODUS
    test dump virgin
  13. The Following User Says Thank You to dell66 For This Useful Post:
    martinracing (10th July, 2014)
  14. #43
    hello
    I had already done the test with this file and no communication with ECU dae
    thanx
  15. #44
    hello, this is a modus dell66 2007 1.5 dci
    is that we can repair the file I believe that he and conrompue
    thank you for your help
  16. #45
    May 2013
    in my opinion this one seal ok,
  17. The Following 2 Users Say Thank You to dell66 For This Useful Post:
    CHAMO (15th December, 2013), martinracing (10th July, 2014)
