Here your file repaired or if it not work write virgin file and code with clip.
Pass PM
Clio3 repaired.rar
No THANKS, no HELP
Pass PM
Clio3 repaired.rar
No THANKS, no HELP
genog (16th June, 2016)
hi friend your dum has repeared try and report pm in your box
i not save pasword. thanks.
Try my dump repaired. If still not work, use Virgin file and code with Clip.
Modus repaired.rar
chikilarme (9th May, 2017), garagetech (17th June, 2016)
Hi, Had a problem with this file. Perhaps i did something wrong. Re wrote dump and did coding in car with DEC Superscan 3. still getting error with steering.
Have i coded this correctly or in fact did i need to do anything after replacing the dump. Please forgive my ignorance, dont normally deal with Renault and this is the first one of these i have had.
Perhaps some kind person could help with the correct process. I have access to a Clip if that would be better, but normally find i can do everything with DEC or AVDI.
Many Thanks
HI Kada2015
Not working car not start
hello, lion0304. thank you very much, please pass
Can someone repair a TRW 54084732L with error DF002 from a Renault Modus ?
Please repair Power Sterring by Modus with error DF002.
Repair or virgin.
Your virgin file.
Best regards.
Dragon
Read again your eeprom, because all 00 or find dump from identical model, then virginise dump.
Best regards.
Dragon
