thank you Friend for the file i will test tomorow .
hi
i tested the dump, it doesnt work, i becoms worster, boarding instrument light dont work cannt see any value of indicators, power steering not work my car diagnostic software can not acess to the power steering calibration ( power steering without assistance )
but the car starts
everyone works and you do not. strange as that.
if the power steering does not go to the diagnosis, possible damage to the wiring
i will check wiring
for you.....
After replacing the ESD control unit, configure the control unit using the parameterization command VP006
"Calibrate the computer" and program the steering angle sensor.
This parameterization requires the following procedure:
- connect the scan tool,
- switch on the ignition and enter into dialogue with the computer of the electric power steering,
- select the menu "Repair Mode",
- enter the parameters using the commands VP006 "Calibrate the computer and programming the angle sensor
turn the steering wheel, and VP004 "Programming the steering angle sensor",
- exit the diagnostic mode: interrupt the dialogue with the computer of the electric power steering
control without shutting down the CLIP device,
- turn off the ignition for at least 15 seconds without disconnecting the battery,
in order for the power steering ECU to take into account the changes made
configurations
- turn on the ignition again and enter into dialogue with the ECU of the electric power steering,
- make sure that the configuration changes are taken into account,
- check the operation of the system (the presence of power steering with the engine running).
martinracing (20th July, 2019)
Hi all
I have also a Clio 3 trw 8200294976-a with def02.I also noticed i have a bad engine relay.Key out but car still running......so replaced and ok now.
Here my file.......
Anybody please can you help me?
monter5555 mod damp
use renolink working very well
yes it works,and dd4all.
but people are lazy and do not use the available information
Thanks for the file Catalizator.Im sure its ok.........but i still got df002 error right away so i think my HW is foulty.
Try to find a second hand modul and try again.
Hi.
I have two steering from modus and booth have errors df002.
Can you clear this error for me.
Thanx advance
Best regards
monter5555 (22nd February, 2019), serikpay (8th October, 2022)
Hi Tomo,
Have a look in your private messages!
Greetings,
tomo776 (23rd February, 2019)
