Page 29 of 32 FirstFirst ... 19242526272829303132 LastLast
Results 421 to 435 of 476
  1. #421
    Sarkan's Avatar
    Modus TRW 8200433517D DF002 faut .Please help
  2. #422
    DK Veteran kams20040's Avatar
    Hello,i have a Renault Modus 8200 433 517--D
    with DEF002 Fault
    eeprom 24lc16
    Please can repaired the dump.
    Many thanks.
  3. #423
    Oct 2018
    kams20040
    <Clear IMMO Code> - Clears immobilizer code from PAS control module.
    New immobilizer code will be transfered from UCH to PAS
    control module on the first ignition OFF/ON cycle.
    thnx.......................pass pm
  4. The Following User Says Thank You to tothzsolt For This Useful Post:
    kams20040 (16th November, 2019)
  5. #424
  6. The Following User Says Thank You to tothzsolt For This Useful Post:
  7. #425
    Hi mate ... steering always strong... etc on cluster ... but no fault on diagnostic... étrange!!
  8. #426
    Oct 2018
    Hi now everything is ok but steering is not good for you then, look at the pump and the oil
  9. #427
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Hi kams20040,
    This is your own dump repaired.
    Greetings,
  10. The Following 2 Users Say Thank You to Louislesinge For This Useful Post:
    kams20040 (16th November, 2019), rafal (16th November, 2019)
  11. #428
    Quote Originally Posted by tothzsolt View Post
    ok mate will check it
    thanks a lot
  12. #429
  13. #430
    Jun 2017
    French Jungle
    Done with RET so could be the same file. Check power on big black and red wires and +12V on the little yellow. There is no oil to check because this is full electric system!
    If controls are full ok and all informations goes to dash (temperature, speed, rpm), replace your EPS.
    Good luck,
  14. #431
    Dec 2013
    Bosna i Hercegovina
    Default renault modus def002
    Hello,i have a MODUS STEERING TRW FAULT... DF002
    8200 433 517 D
    I'm asking for help
  15. #432
    Feb 2016
    hi,can u send me a password to open file.thanks
  16. #433
    Dec 2013
    Bosna i Hercegovina
    Quote Originally Posted by dzevad View Post
    8200 433 517 D
    I'm asking for help
    please some solution
  17. #434
    Oct 2018
    dzevad
    hi clear df002 dtc code and clear immo vrgin and crc repaired good...
    solution 10000%%%%
    test and report
    thnx.......pass pm
  18. The Following User Says Thank You to tothzsolt For This Useful Post:
    dzevad (5th December, 2019)
  19. #435
    Dec 2013
    Bosna i Hercegovina
    dzevad
    solution 10000%%%%
    test and report
    thnx.......pass pm
    no pass. inbox empty
