Need IMMO OFF IAW 59F.M2 hw 002 \ 1702 - MFL
Results 1 to 15 of 28
    xanubysx's Avatar
    Sep 2010
    EUROPE
    Default Need IMMO OFF IAW 59F.M2 hw 002 \ 1702 - MFL
    Hi guy, i read flash from Fiat Punto 1.2 for help Marelli Decoder ... and need 100% immo off file... orig post down ... or you can edit the file reliably by a program? For example, immo decoder 3.2?
    Thank you for help
    Number ecu:
    IAW 59F.M2
    IAW 59F.M2 hw 002 1702 - MFL
    267 99
    61600.389.04
    B671
    46760606
    1702-MFL.ZIP
    Do not forget to THANKS !
    SWIFTECH FULL
    ECM Titanium FULL
    KESS V3
    AUTOTUNERS
    B-FLASH
    WINOLS
    TOPDONE
    AUTEL
    FILE SERVISE .. web under construction
    xanubysx's Avatar
    Sep 2010
    EUROPE
    Resolved.. car is now ok immo OFF
    SWIFTECH FULL
    ECM Titanium FULL
    KESS V3
    AUTOTUNERS
    B-FLASH
    WINOLS
    TOPDONE
    AUTEL
    xanubysx's Avatar
    Sep 2010
    EUROPE
    Default immo
    Problem solved, now is ok . . .
    SWIFTECH FULL
    ECM Titanium FULL
    KESS V3
    AUTOTUNERS
    B-FLASH
    WINOLS
    TOPDONE
    AUTEL
  4. The Following User Says Thank You to xanubysx For This Useful Post:
    taxi300 (16th May, 2013)
    hi please can you help me i need immo off for my car fiat punto 1.2 YEAR 2001 ECU MM IAW 59F
    THANKS
    xanubysx's Avatar
    Sep 2010
    EUROPE
    Post your file
    SWIFTECH FULL
    ECM Titanium FULL
    KESS V3
    AUTOTUNERS
    B-FLASH
    WINOLS
    TOPDONE
    AUTEL
    aslamaslam's Avatar
    Feb 2012
    FRANCE
    hi
    can you help me i need immo off for fiat punto 1.2 ECU MM IAW 59F
    and what the device use for this pls
    thenks
    xanubysx's Avatar
    Sep 2010
    EUROPE
    I use IAW Decoder ... you use KWP to read.. and post orig file ...
    SWIFTECH FULL
    ECM Titanium FULL
    KESS V3
    AUTOTUNERS
    B-FLASH
    WINOLS
    TOPDONE
    AUTEL
    EU
    Quote Originally Posted by xanubysx View Post
    Can you help me with immo off ? Ecu is IAW59F HW002. I have read with Mpps v12. In attach ori file, I hope it is good read.
  10. #9
    Dec 2015
    HI! Can you help me with immo off ? Ecu is IAW59F HW002.
  11. #10
    Dupnitza, Bulgaria
    Here you are...
  12. #11
    Jun 2014
  13. #12
    Jun 2012
    HI! Can you help me with immo off? Ecu is IAW59F HW002 1702-MFL.
  14. #13
    kumbari's Avatar
    Germany
    Default Fiat punto iaw59fhw002 need immo off
    Fiat punto iaw59f hw002.1702-mfl need immo off
  15. The Following User Says Thank You to kumbari For This Useful Post:
    LabraxDz (9th August, 2019)
  16. #14
    Jan 2016
    Hi mates
    my ori key are broken, can I used key from scrapyard program in to BSI ??
    I can get pincode
    I dont have new transponder to make new key
    car Punto 1.2 8v Y2000 BSI Delphi ecu IAW 59F.M2 hw 002 \ 1702 - MFL
  17. #15
    pls i need immo off i read with fgtechv54 iaw59f.bp
