SOLUTION PROBLEM DM500S
Results 1 to 9 of 9
    May 2008
    Lightbulb SOLUTION PROBLEM DM500S
    HI ALL MY FRIENS
    i 'm new in this forum and i need help please
    i'had flashed my dream 500S with GEMINI 4.31 and when i readed that there is a problem with this image i tried to flash a nother image with dreamup
    i do it but the image still the same for GEMINI 4.31
    HERE MY LAST FLASH
    19:59:41 OK, flash erased
    20:00:09 Found no valid jffs2 in image, flash-erase not supported
    20:00:09 Uploading file to box...
    20:13:42 calculating CRC32 on STB...
    20:13:43 erasing flash...
    20:14:22 box is flashing from its memory...
    20:14:58 calculating CRC32 on STB's flash...
    20:15:07 OK, flash-copy succeeded
    20:16:49 Found no valid jffs2 in image, flash-erase not supported
    20:16:49 Uploading file to box...
    20:30:32 calculating CRC32 on STB...
    20:30:33 erasing flash...
    20:31:12 box is flashing from its memory...
    20:31:40 calculating CRC32 on STB's flash...
    20:31:49 OK, flash-copy succeeded
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Download the official firmware from the dream multimedia website and flash that.
    http://www.dream-multimedia-tv.de/english/downloads.php
    Jun 2008
    Download the Nabilo Maxvar v0.8 firmware from the Nabilosat website and flash that.
    Aug 2010
    bonjour j'ai acheter un dm 500s je l'ai flasher avec image gemini 4.70 var max apr?s 3 jour un signale clignante sur l'?cran clone,je l'ai ?teint et apr?s led noir et bloquer a jamais quoi-je dois faire aider moi S V P voila mon gmail
    1-maria06kh@gmail.com
    2-maria06kh@voila.fr
    Aug 2010
    bonjour j'ai acheter un dm 500s je l'ai flasher avec image gemini 4.70 var max apr?s 3 jour un signale clignante sur l'?cran clone,je l'ai ?teint et apr?s led noir et bloquer a jamais jai essayer de flasherai avec dreamup et flashwizar et dcc pas de connections quoi-je dois faire aider moi S V P voila mon gmail
    Quote Originally Posted by maria06 View Post
    sounds like clone bomb destroyed your box so you need to jtag your box there is a guide how to do it at fallowing link
    http://www.digital-kaos.co.uk/forums...reambox-11795/
    it is not easy mind also if you manage to jtag it do not use Gemini image use bh or pli jade ok 
    Aug 2010
    bonjour Muzzy25
    je l'ai pris chez le r?parateur il n'a pas de jtag a souder donc un flash certainement merci
    Feb 2013
    merc i tooooooooooooo
    Old Git PaphosAL's Avatar
    Mar 2008
    I honestly cannot believe that total noobs are meddling in such dark arts like this... Why not stick to well-known clone-friendly images like OpenPLi or Commando 14.7?
    Yours faithfully,
    Baffled and bewildered
    Somewhere north of London
    UK
