Page 8 of 8 FirstFirst ... 345678
Results 106 to 119 of 119
  1. #106
    Nov 2010
    Default IP address query
    Hi there....I am very new to the world of Dreambox.
    I am setting it up to record to my pc. There are refernces to ip address and usually is 192.168.etc.
    My pc is one of 4 and connected to a modem / router.
    When I do the command "ipconfig" on my pc I get 10.1.1.3. Is this the ip address I should use on the Dreambox configuration.
    Any help would be appreciated.
    Ray
  2. #107
    Mar 2011
    trying to set up my external hard drive that is connected to my Netgear WNDR3400 router with usb cable. I can access the hard drive on my pc but not on my Dreambox 500s. In my router settings page i have 4 different options to access it. ftp, ftp via internet, Http, and Http via internet. what one should i use? My router has \\readyshare\USB_Storage listed as available folders. Im running PLI jade3 and am in the web interface trying to mount no luck. any help please?
  3. #108
    Feb 2009
    I got mine mounted and it started recording and then crashed the box. Any suggestions?
  4. #109
    Nov 2010
    Hi all,
    I read your post regarding setting up a HDD for recording and wonder if you can help me out.
    I am using a Buffalo Linkstation NAS but I couldn't mount it using the tutorial found in the thread:
    Here are my settings:
    I am using Newnigma2 image on my 800HD and I have created a folder "Recordings" in the root directory of my NAS. The username and password are the login details when I access the NAS from a web browser.
    Active: enable
    Local share name: Recordings
    Mount type: CIFS share
    Server IP: 192.168.2.7
    Server share: media/hdd
    use as HDD replacement: yes
    Mount options: rw
    Username: admin
    Password: ********
    Devilfish mentioned using SMBFS for NAS enclosure but I cannot find it in the mount type option. I can only choose between NFS and CIFS.
    Any help would be much appreciated, thanks..
  5. #110
    Need Help... I able to config to mount my drive to the dreambox but when recording the audio and video freeze every 2-3 seconds for a second when playback. Any tips ?
    Running PLi Image with PC i7 Processor with Windows 7. Tried on Windows XP also same problem.
    Anyone can help my problem...
  6. #111
    Newbie siletto's Avatar
    Dec 2011
    Default Need help setting up to record with Buffalo Linkstation Pro Duo
    I have gone through all the pages in this thread with no avail.
    Need help filling this page just to start off on the right track.
    Client directory:
    ServerDirectory:
    Remote Host Name/IP:
    I have given static address for my dreambox 500c (192.168.1.135) and NAS (192.168.1.203).
    I have created a folder (RECORDINGS) in my NAS web interface. Allowed for read & write mode. Guest access is enabled.
  7. #112
    Hi I have problem to mount my drive on DM500S.
    Can anyone help me set the DM500S settings for mount drive?
    NAS is Buffalo TeraStation PRO TS-H2.0TGL/R5-EU
    My router IP: 192.168.1.1 (Netgear)
    DM500S IP: 192.168.1.10
    My NAS IP: 192.168.1.7 (only admin access for configuration, no file access)
    My NAS folder: \\NAS-001\DreamBox (shared folder)
    NAS user and password: dreambox
    My problem is that with IP I not have access to shared folder, I need to use Network manager to access files and folders.
    How can I set this on DM500S?
    Anyone have any solutions?
  8. #113
    Dec 2011
    Default Help
    when i do this i get a error message can any on help
  9. #114
    Mar 2012
    Hi guys,
    i need yr help to setup my stuff....
    1. i have dreambox 500s and i want to record directly to NAS (Synology DS212J)
    2. on my synology i have a shared folder "Downloads" in which i want my recordings go in .
    the location is :
    i. smb://192.168.2.9/Downloads
    ii. \\PGM_DISKSTATION\Downloads
    My questions are:
    1.on the add mount point window filestystem i will choose 3= smbfs, right ?
    2. automount check , right ?
    3. client directory and server directory , how i will enter the location ?
    4. ip : the ip of the NAS
    5.user name , pass - selfexplanatory
    it has some boxes on the right, should i check some of them ? the last 4 are checked .....
    Sorry for my noobs questions ((
    Thanks in advance for yr help guys .....
  10. #115
    Apr 2012
    guys how do I record to pc. first I am using Cnigma2 image.
    so first thing I do is go to bluepanel>setup>automount editor>add. then I key in my ip address n set the rest.
    after which I still cant record. reading the instructions, I do not have communications setup, so am I doing rightly?
  11. #116
    Jan 2013
    thanks man
  12. #117
    Jan 2013
    What is the format of the recorded media?
    Can I setup or configure the recording format type?
    Thanks.
  13. #118
    DK Veteran uu161's Avatar
    May 2012
    Quote Originally Posted by ivony View Post
    Thanks.
    TS Format
    no u can't only TS
    if not use video converter to any format you wish to
    if you like the post use the Like button located bottom right corner of each post
    if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
  14. #119
    Aug 2013
    NEED HELP!!!
    I cant mount to my network drive using engima2 image.
    Anyone can help ?
