Results 1 to 15 of 27
    stoke on trent - uk
    Exclamation problem flashing image using null modem cable
    this is the first time ive attempted to flash my dbox. i went through the guide step by step, very slowley. everything was going peachy untill i put the command 'cp1.1 120000 10020000 IF8000' i waited for over half an hour....nothing happened. so i left it over night and still nothing! i gave my box to my usuall guy who does my flashing and he cant seem to send the image. is there any body who can pull me out of the shit or have i shagged my box?? pls help many thanx!
    V.I.P. Member Fergal's Avatar
    Aug 2008
    Does the box boot up if it does and you have a ethernet crossover cable you can use flashfxp to ftp the image into the /tmp folder and use the dbox menu's and remote to flash it
    or if it dont bootup use both cables and IFA to flash it
    if you dont have a crossover cable and thats why you are doing it the nullmodem cable only way you have typed the command in wrong
    cp.l 120000 10020000 1F8000 press enter
    (***Note that this command starts CP.L and not CP.1, all lower case though***)
    Wait for Done. The procedure takes about 2 minutes.
    Jun 2008
    Quote Originally Posted by kingdalg View Post
    try ethernet and ifa xover cable if not thru router
    cheers
    stoke on trent - uk
    im just trying it again. many thanx for the info, im very grateful. is there a quicker way of flashing the box. when my guy flashes mine it takes 5 mins max! appriciate any info, cheers
    Jun 2008
    if u can get into the img ftp is the quickest (5 mins) if not ethernet cable (xover) with ifa is next quickest
    cheers
    stoke on trent - uk
    is there a differance between normal xover and ethernet cable?
    plasterer's Avatar
    Jun 2008
    Mersyside
    If you can network to the box it can be done in 5 mins
    With a nokia and Ifa about the same,but you then need to add the bits
    With a 1 x sagem and IFA 15 to 20 mins
    As long as the end result is a winner it dont matter,
    Its not a race ..................Paul
    PAUL
    Jun 2008
    yes few wires crossed on crossover
    got a router?
    stoke on trent - uk
    i first tried using a ifa program but when it came to step 2 ' choose a network card' the tab bar was just blank. any thoughts?
    stoke on trent - uk
    yeh ive got a wireless router.
    Jun 2008
    connect an normal ethernet cable dbox - router
    can u get the box to boot?
    stoke on trent - uk
    oh i see, ur using the router as a mirror effect. do u use both null and ethernet cable on ifa program?
  13. #13
    Jun 2008
    no need to use null unless u want a log
  14. #14
    stoke on trent - uk
    ive just entered cp.l 120000 10020000 IF8000 after waiting over an hour. it sais 'zero length' ?????
  15. #15
    Jun 2008
    for hyperterminal u need null modem cable
    for ifa dbox thru router use ethernet cable
    for ifa dbox straight to pc use xover cable
    if u can boot the box - reflash using ftp
