Page 3 of 23 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 339
  1. #31
    Mar 2012
    don't see the download link
  2. #32
    digicon's Avatar
    Quote Originally Posted by mikeysauce View Post
    Oh! Dear try reading through the 3 pages of the thread and on page 2 you will see this here: http://www.digital-kaos.co.uk/forums...ml#post2005077
  3. #33
    Member Medlock's Avatar
    Sep 2010
    Manchester
    If your referring to the "Irish Variation" channel list its not done, when its ready I'll post it.
  4. #34
    happy_highlander's Avatar
    Aug 2010
    Stick the irish channels in a bouquet on there own and let them either use that or they can drag them across same as the other users do with their regional variations
  5. #35
    Sep 2010
    Manchester
    Default looks to be working OK.
    Quote Originally Posted by happy_highlander View Post
    Looks like I've got it sorted, seems to be working OK. so hope to post a full channel list this weekend?
  6. #36
    Sep 2010
    Manchester
    Default UPDATE: 22/06/2013 - (SKY UK (28.2E) ENiGMA2 Bouquets And Picons)
    UPDATE: 22/06/2013
    Updated Channel List Bouquets and Picons - 22/06/13
    12 new updated Picons added also
    This update has a "Irish Variations" Bouquet.
    Not sure of all the Irish variations channels, Comedy Central`s etc, so if those that use them want to post which they are I'll add then next time round.
    Channel listings and bouquets are positioned and in keeping with the current Sky HD layout.
    (Edit Your Own BBC & ITV Region Channels In DreamboxEDIT)
    MEDLOCK - "Sgt BrickTop"
  7. The Following User Says Thank You to Medlock For This Useful Post:
    mcmlxviii (24th June, 2013)
  8. #37
    Stiil Disney hd problem and sky select?
  9. #38
    Sep 2010
    Manchester
    Quote Originally Posted by jewels01 View Post
    Both channels working fine from where I am.
  10. #39
    Not sure what Im doing wrong, sd works fine just the hd version even when I click all channels and select from there. Any ideas? ps you doing a good job! (ex B16 MCC user)
  11. #40
    Sep 2010
    Manchester
    Maybe worth going back to your previous channel list just to make sure all was working prior or if others are having the same problem they maybe able to help?
  12. #41
    Jun 2013
    I have the same problem, has only stared happening since i installed the 28.2 Auto Bouquet Plugin by Lraizer.
  13. #42
    Aug 2010
    Not meaning to intrude on your thread Medlock but can you two lads that are having problems with the two channels check the frequency and pids and more importantly the fec to see if they match the kos settings or post them on thread and I'll check them. If they do match do a single transponder scan. The channels should then work but the fec may have changed. Don't ask me why it does it but since changing my setup to using a diseqc switch itv hd will only work with different fec on same tp settings.
  14. #43
    Would I supply this by going into dreambox edit to view bouquet or do I get the information another way for you. Many thanks for taking the time to help.
  15. #44
    My Disney HD is 12168 V29500 3/4 QPSK if that helps
  16. #45
    Aug 2010
    Those settings are correct. You haven't given me the pid but no matter. On the same transponder you have sky modern greats sky drama sky scifi/horror and sky comedy all hd. If you can see these then the video pid must be wrong for Disney. If you do a single transponder scan on this transponder it should sort Disney for you.
