Wii USB HD Loader - Page 3
Page 3 of 44 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 647
  1. #31
    May 2009
    Hey, I'm I hope I can get this from ya but all the other usb loaders I have tried keep coming up with errors. I have a Toshiba 300gb ext drive formatted with 200gb WBFS and 100gb Fat32. Do you see any problems with that? It's seems my wii doesnt even know the HD is there.
  2. #32
    DK Veteran Yumraaj's Avatar
    Quote Originally Posted by niallgrant View Post
    Did you install the cIOS 36 Rev installer? It is important you do that before you try to access the Drive.
  3. #33
    Oct 2008
    I have tried various usb loaders but keep getting the following:
    error ret = -1)
    any advice on what the problem could be, the wii is seeing the drive.
  4. #34
    Quote Originally Posted by victor1 View Post
    error ret = -1)
    If the wii is seeing the drive, may be it is not formatted properly! I had this problem before after a second format it was fine. Try this and see. Hope this help.
  5. #35
    Oct 2008
    Hi thanks for the reply,I used WBFS manager to format the drive and loaded it with roms, do you think this could be the problem ? how should I format....fat or fat32 ?
  6. #36
    Oct 2008
    well no luck with the reformat, think I'll have to stick with discs for now
  7. #37
    Oct 2008
    Not having much luck with this, bought dvd-r tdk and the wii wouldn't read them, then got Arita and my dvd writer keeps spitting them out eventually got some to work using cheap ridisk, but would prefer the usb drive as I'm worried about the wiis laser.
  8. #38
    I would format it as FAT32 first then WBFS. Have you tried to format it using your wii console itself? Try that first and see.
  9. #39
    Nov 2008
    Hi, I got a Western Digital HD,(1T) will work or not???
    Thank you
  10. #40
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Why not just try it and see for yourself. It's not that much hassle to just go ahead and test something for yourself is it ?
  11. #41
    Oct 2008
    Ok update I got the loader working, by installing cIOS36_rev9-via network install. my 8gb USB key works well, but my 40gb lappy drive in usb enclosure didn't at least I'm a lot closer to success now, thans
  12. #42
    It's a bit picky at the minute regarding drives. There is a list around on the net which will guide to which drive is compatible with USB Loader, Try google mate.
    Had some spare time so did it for you:
    http://wiki.gbatemp.net/wiki/index.p...atibility_List
  13. #43
    Top Poster undercoverjamil's Avatar
    Apr 2009
    do u need to chip your wii for this
  14. #44
    Quote Originally Posted by undercoverjamil View Post
    No, you dont need to chip your wii mate.
  15. #45
    Oct 2008
    Thanks yumraaj, pleased to say I've now got this working, I had a spare sata drive, stuck it in an enclosure and it works superbly, a grand job
