its a buffalo 500g
its a buffalo 500g
Are you using the whole drive just for wii or is it partitioned? If it is partitioned, make sure the partitions are set as primary.
If it is the whole 500g you plan to use then your wii should have no trouble recognising it. I have given you revision 9 because people on the internet are having problems with other versions.
ye its the whole drive that im going to use boght it just for the wii, stops kids ruining disks when left around thats if i get it going.
i havetried that wbfs a few times now and still geting errors.
I am now formatting it on pc n see what happens.
am i using correct wbfs? (v2)
if this dosnt work is thier special way to format through wii?
thx again for help
can plug hd into wii and put a disc in and it has copied the first few i have tried and played back without disc no problem.
but when trying to put games on from pc using wbfs manager 2.0 i keep getting error message as if it cant see hd?
When i have plugged the hd back into pc if i go in2 my computer and try clicking on the hd file (for wii) it is asking me to format the hd before i caan use it
where am i going wrong?
thx
daz
Whatever happen please dont format it when it is connected to your PC. It is a different format which windows cant recognise that is why it's asking you to format it. What you can do is try the latest WBFS Manager which is located here:
WBFS Manager - Release: WBFS Manager 3.0
If this dont work try this one instead, it's called WBFS Intelligent Gui:
MEGAUPLOAD - The leading online storage and file delivery service
Hopefully this will help you mate
sorry to jump in but you say you have copied games to your hd when you load your hd onto your pc via the wbfs and picked and loaded the drive can you see the games. if so and you still get errors loading then i would try reformating with the wbfs programe
i use a buffalow 500 drivestation and have no issues after formating the drive via the wbfs programe dont formate the drive after this with the pc it will always ask but just cancel.
cheers johny48
thx just got in from work will give try l8r let u know how i do
daz
yes m8 new version worked a treat copied games to hd now to try it out thx for help
daz
cheers for downlods diddydave much appreciated i have one problem i cannot seem to load cios i have tried other ones to it keeps giving me that erroe ret = 1 .im conected to net on wii i have tried 3 different hardrives and formated with wbft what am i doing wrong mate cheers for your time thanks
:rangers
Ret=1 means not able to see a Ext USB Drive. Try this for size make sure you plug in the ext hd drive in the right hand side if the wii as you look at it from behind. This is required if you have CISO Rev13b installed. The left side is reserved for usb devices such as usb mics
I'm completely new to this - so please some patience...
First of all I'm on Wii 4.0 before I started looking into softmodding - apparently I can't downgrade the system menu version... so I need something that works with Wii 4.0.
I'm interested in playing back-up games from either a Back-up Launcher (Gamma apparently does NOT work with Wii 4.0) or USB Loader (I like the look of WiiCoverFlow).
I'd like to complete the following: How Do I install the Usb loader on the Nintendo Wii 4.0? - Yahoo! Answers
I've managed to install the Bannerbomb mod to get the HBC... tick.
I then found out that I need to upgrade the cIOS. I've managed to download the cIOS36 Rev 10 as well as the Installer that goes with it. I've put the wad on the SD root, and created a "cIOS Rev 10" folder inside the "app" folder, which contains the Installer program.
When I run this on the Wii, it starts to execute & the screen fills up: patch #1 (or whatever it says - can't remember exactly) - OK, patch #3 - OK, then on patch #5 it errors & I get an error code of "Ret = -1".
Please help...
