Page 5 of 44 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 647
  1. #61
    DK Veteran Yumraaj's Avatar
    Quote Originally Posted by rod View Post
    dear yumraaji have looked everywhere but i could not find a way to create a partition without delete everything on my external hdd, please can u tell me how to do it?
    tks
    Here you go mate:
    How to Partition a Hard Drive | eHow.com
    OR
    http://www.partition-tool.com/easeus...-partition.htm
    Note: Some people say it will NOT delete any existing data but to be on the safe side, I would back it up.
    Hope this help.
  2. #62
    Sep 2008
    ive done every thig but when i put theUSB-Loader_v1.dol file in the sd and go to homebrew nothing happen, what should i do now
  3. #63
    You need to rename USB-Loader_v1.dol to boot.dol. Then go to homebrew channel and launch it and make sure it is in the apps folder on your SD card.
  4. #64
    Sep 2008
    apps folder on your SD card?
    how do i do it?
    sorry
  5. #65
    you should have a folder on your SD card called apps. make a new folder inside the apps folder and name it usbloader and copy the usbloader.dol in the folder.
    N.B: Dont forget to rename it to boot.dol
  6. #66
    Sep 2008
    ive done it but when i open the homebrew channel come on
    Exception (isi)
    (lots of number )
    stack dump
  7. #67
    I have never come across this one before mate Are you sure that you have followed the instruction properly?
  8. #68
    Top Poster undercoverjamil's Avatar
    Apr 2009
    i have got a massive problem. none of my usb's work with this. I have tried 6 different ones.
    also to rod that also happened to me first. First of all get rid of everything else on your sd card first. then do it. if u have wii sytem 4.0 use bannerbomb.
  9. #69
    May 2009
    So i got this up and running with no trouble, DL some games and copied some games and the worked fine. SSX Blur loads up to the warning screen then the wii freezes and the controller turns off. have to turn off the wii to get back to the menu. i have cIOS36_rev10, and have tried the usb loaders SDUSB-Loader_v1.5, WiiCoverFlow-RC3 and SDUSB-Loader_cfg31b. Read about this problem with people using backup loader and their fix is to use [2106]IOSPatcher_1.0 and change the iso setting to 249 or 30. Does anyone have a fix to get this game working?
    just thought about it and since we use iso36 then i will use iso patcher and change the game iso to 36. will update if it works
    ::update:: No dice. didnt work when changed gameiso to 36, after warning screen it dumped back to wii menu
  10. #70
    Exception (isi)
    (lots of number )
    stack dump
    Rod have you manage to install it again mate?
  11. #71
    May 2009
    .I installed USB Loader the other day, but I have been having problems getting it to work. I am not sure if the problem is due to an unsupported drive or because I have done something a little funny in the software. So let me throw out what it does.
    I have tried two different drives, but I get the ret=-1 error. It comes up instantly, as soon as I hit A on "USB Hard Drive". The part that makes me think it is software is that it does exactly the same thing when there is no drive connected, when when I tell it to look at the SD card.
    Is this normal behavior for an unsupported/disconnected drive? Neither of my drives are on the compatibility list. If this is the expected behavior I would be willing to go buy a second drive and use the existing one for backup, but I would like to be more sure before spending that kind of money again.
    Oh, and I have tried plugging the drives in at different times and using different ports, but it hasn't made a difference. I have plugged in unformatted drives as well as drives that have been partitioned and formatted with WBFS, and then had games loaded to them. I have installed IOS36 rev 10.
  12. #72
    Apr 2009
    what sort of memory sticks work for this as i can't get a single one to work.
    Is there a minimum size the memory stick has to be.
  13. #73
    Quote Originally Posted by undercoverjamil View Post
    Quote Originally Posted by Axess Denyd View Post
    Try and install this latest update and see what happen mate.
    Digital Kaos - Downloads - cIOS36_rev12-Installer
  14. #74
    Sep 2008
    hi mate it is not working, ive put the file in the sd with the other name and went to homebrew and it worked, but when i turn on my usb hd and press to play a game come with that screen again, i think my usb hd dosent work
  15. #75
    May 2009
    Default cIOS Installer
    i git a error ret 2011 and i haf try 5 times vot can i do, i haf 4.0e
