Page 6 of 44 FirstFirst 123456789101116 ... LastLast
Results 76 to 90 of 647
  1. #76
    May 2009
    Finally got mine working yesterday. I got IOS36rev10 from another source and it worked perfectly. I guess the one I originally had was corrupted or something--the filenames were the same, but obivously one didn't work.
  2. #77
    Sep 2008
    hi guys i got another usb loader from another site that says
    Just extract the "USB Loader GX-ULNR r366.wad" to your SD:/wad folder and install with Wad Manager.
    but when i put this in wad folder i cant see it, can someone tell how to do it?
    I tryed the one from here and it dosent work on my usb hd, tks
  3. #78
    DK Veteran Yumraaj's Avatar
    Quote Originally Posted by rod View Post
    Just make sure you dont have more than 8 wad files in the folder because wad manager cant read more than 8.
  4. #79
    Sep 2008
    is that right?
    put this file in wad folder and go to homebrew or i have to create another folder too?
    tks
  5. #80
    Sep 2008
    i downloaded the cIOS36_rev12-Installer but how can i check if this is not in mine already?
  6. #81
    Top Poster undercoverjamil's Avatar
    Apr 2009
    Quote Originally Posted by yumraaj View Post
    wat is wad manager. cos i dont have it and have never heard of it.
  7. #82
    is that right?
    tks
    No you dont have to create another one, just put this one in your existing one and that's it
    Plug you Sd card in your PC, double click on it and you will see a folder call apps, open it and see if it is there already or you can plug it into your wii, launch HBC and see if it there.
    Quote Originally Posted by undercoverjamil View Post
    Wad manager is an application that you use to install wad files. Basically you put the main application in your apps folder on your SD card and use HBC to launch it. All your wad files should be in a folder call wad which should be in the root of the SD card.
  8. #83
    May 2009
    Quote Originally Posted by teske View Post
    Basically you put the Wii USB HD Loader Channel.wad file in the wad folder which should be in the root of the SD card. Then go to HBC and launch Wadmanager. Press A button then choose SD and press A button again. You should be able the file now, select it with D-Pad (Arrow/Directional Keys) and press + and wait for it.
  10. #85
    May 2009
    okay i will do dat thk
  11. #86
    Any probs, just get back to me. It's no trouble at all. I know how it's like when you just started, I was the same! Now It's my turn to help others.
  12. #87
    Sep 2008
    hi guys ive done every thing but when i got to usb loader gx channel it says that the usb is not formated when it aks for format it says that cant format, what can i do now, tks
  13. #88
    What is the make and model of you drive mate?
  14. #89
    Apr 2009
    Wad manager is an application that you use to install wad files. Basically you put the main application in your apps folder on your SD card and use HBC to launch it. All your wad files should be in a folder call wad which should be in the root of the SD card.[/QUOTE]
    i don't have a wad folder or any wad files
  15. #90
    Sep 2008
    Toshiba (PX1267E-1G32) 320 GB USB 2.0 Hard Drive this is my hdd
