Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    pierre renault's Avatar
    Jan 2013
    Default R270 PROBLEM M35080 HELP
    Good day. Today arrived my R270 CAS4. have problems, start reading and before you reach the end, as in the picture, I can not do anything with adapter M35080.
    Please can someone help?
    thank you
    Sep 2012
    I am using R270 for erase 35080 series... where is the picture??
    Jan 2013
    sorry about the photo
    GB
    Read again or/and clean the pins of the eeprom.
    Jan 2013
    already cleaned several time! and experimented with several M35080 always the same problem, also resoldei resistances.
    Anything else I can do??
    thank you
    davecooper47's Avatar
    Dec 2010
    080D0WQ is not a 35080. You need to select the right chip. Bottom right hand corner, advanced function, select 080/160 35080, you will then get a pop up box in which you should select the exact eeprom ie: 35080 V6/VP, D80, D160 35080 3/6. I have never had any joy erasing 35080 VP's or V6's with this kit (only partially erases) but D80's work everytime without fail and very fast. I can see by your picture that you are not selecting this properly.
  7. The Following User Says Thank You to davecooper47 For This Useful Post:
    rtbdiagnostic (1st June, 2019)
    Jan 2013
    did just that selected eprom correctly, starts reading and read error.
    Dec 2010
    You have asked for help reading a 35080 and your picture clearly shows that you have selected an 080D0WQ. You cannot do this with this kit. You must select the right chip.
  10. #9
    Jan 2013
    yes i tried the correct version. I experienced M35080 (3.6) VP, V6, 080DW, all well chosen but always the same problem, before reading to reach the end (READ ERROR)
  11. #10
    You might be better of sending back to supplier for exchange
  12. #11
    Jan 2013
    Experienced in CAS3 works well! But my interest in the function was R270, M35080 eraser v6, vp, 080d0WQ. When I experienced the first time reading M35080 did not read anything, then I re-weld or components entam now start playback, but for reading before coming to an end, as the image is then says: READ ERROR (((in 20 attempts, one ever read well))
  13. #12
    Dec 2010
    There must be a problem with your unit. When I bought my R270, I did not expect it to erase 35080's because some people saying it would not work, but it has worked on every CAS. EZS, 080D and 160D chip I have ever done. And it is very fast.
  14. #13
    Sep 2012
    When selecting eeprom select Type 2... also push down on the eeprom while inside the socket.
  15. #14
    Jan 2013
    I tried all the possibilities, until welding directly on eprom adapter, but even before resoltado Finalize reading blocks READ ERROR, or noticed that my not have a component? or will be like? as in the picture, annotated in red. Anyone know the reference of the components noted in blue?
  16. #15
    batandball's Avatar
    May 2011
    Quote Originally Posted by davecooper47 View Post
    I agree with Dave, mine works spot on, D80 less than 1 minute VP,s take longer, but works every time. Just send it back cos if you f--k about with it you'll get no exchange
    If it works use it
    BatandBall
