why not swap eeprom 93c66 from old bcm to new bcm and try to star car if not read dump and poste here a give you pin
Hello mates,
I recently changed the ECM of a Nissan Wingroad Y12 MR18DE 2006 with a used one, now the car is immobilized.
I don't know if I need to virginize the ECM or reprogram the BCM with the PIN code. The problem is that someone peeled the sticker on the BCM wich had the serial number. Is there a way to read the serial or pin number with a scan tool?, I am using a X431 scanner
Here is a picture of the BCM
this localisation eeprom 93c66 in bcm read dump for pin
Thanks for the answer mate, but I forgot to mention that this Nissan has SMART KEY.
And I didn't find any 93C66 on the board.
here are some pictures
DSC01967.JPGDSC01971.JPGI
try to read this eeprom with 93C66 in picture
southerndragon (25th June, 2013)
hello mate, the EEPROM in the picture is A82C250 I think is used for CAN communication, thanks
RL56 = 93C56 - read it.
I pulled the PIN code 1F2F6 with my old X431 superscanner, it had a PIN READ function I missed, calculated the PIN with the super code calculator and thats all
it started right away.
Thank very much to all the members for the help provided
