Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    https://t.me/pump_upp
    Default VW passat 2.0 TDI EDC16U31 need remove DPF
    Hi all
    Can anyone help me please to remove DPF from passat 2.0 with EDC16U31 !
    ECUSAFE and VOLTA dont work
    here ori file readed ith AVDI
    thanks in advance
  2. The Following User Says Thank You to bnad3m For This Useful Post:
    recyclonic (20th June, 2018)
  3. #2
    use galletto,mmps,magpro file size should be 2mb.
    br
    ok m8, here file read with galetto
    thank you
    kevfield's Avatar
    uk
    Your file off
    Thanks kev
  6. The Following User Says Thank You to kevfield For This Useful Post:
    bnad3m (25th June, 2013)
    thank you KEVFIELD for you help but your file dont work, any solution !
    thank you
  8. #6
    Senior Member Diagnosticated's Avatar
    Mar 2011
    Use winols. 16 bit HiLo. Change address 54178 from 00256 to 00000. DPF is off.
  9. #7
    1ED4F0, i believe this is where switch is..i dunno for sure...i had the solution but lost my notes..and i don tlike testing on others people cars
  10. #8
    kevfield's Avatar
    uk
    Quote Originally Posted by Diagnosticated View Post
    exactly how i made but no work !!!!!!!
    reset soot counters ???? and pressure sensor ???
    Thanks kev
  11. #9
    Nio's Avatar
    address 54178 does not have dpf solution on this case. regards.
    "IF YOU THINK PROFESSIONAL PEOPLE COST YOU A LOT, IS BECAUSE YOU DID NOT KNOW HOW MUCH WILL COST YOU AN UNQUALIFIED"
  12. #10
    Nio's Avatar
    Quote Originally Posted by ominimicu View Post
    I don't think is switch...mmmm. Regards.
  13. #11
    1D4178 line
  14. #12
    kevfield's Avatar
    uk
    Switch
    Thanks kev
  15. #13
    solved thank you to all
  16. #14
    Solved how? with swtich i Mentioned or how?
  17. #15
    kevfield's Avatar
    uk
    Yes please let us know how you solved it ????
    Thanks kev
