VW passat 2.0 TDI EDC16U31 need remove DPF - Page 2
Results 16 to 30 of 31
  1. #16
    Senior Member Diagnosticated's Avatar
    Mar 2011
    Quote Originally Posted by bnad3m View Post
    thank you KEVFIELD for you help but your file dont work, any solution !
    thank you
    What engine is in this passat?
  2. #17
    https://t.me/pump_upp
    hi all, sorry for the late, customer come with EGT Sensor ( Exhaust Temp G235) i want to DPF OFF to deactivate the sensor, i write kevfield file but glow indicator lamp still flashing... i found EGT Sensor with cut wire, i solder the wire and all is ok.
    thank you
  3. #18
    Mar 2011
    Quote Originally Posted by Nio View Post
    address 54178 does not have dpf solution on this case. regards.
    I checked 15 files yesterday. All of them had the switch in this position or were set to 00000 as they were non dpf cars. How can this address be wrong?
  4. #19
    kevfield's Avatar
    uk
    Did you read your file via bdm ?? mat be this is differnce ?????????/
    Thanks kev
  5. #20
    Do you think setting the switch from 01 to 00 is enough?
  6. #21
    hi,
    dpf_switch can't clear the error "EGT Sensor ( Exhaust Temp G235)" !!
  7. #22
    Feb 2012
    romania
    I can help me someone canceled particulate filter in 2004 passat? MPPs is read
    2.0 tdi passat dpf off.rar
  8. #23
    Jun 2013
    EU
    Quote Originally Posted by cristecristian View Post
    Here your file
    Regards,
  9. The Following User Says Thank You to morgano For This Useful Post:
    cristecristian (13th October, 2014)
  10. #24
    Feb 2012
    romania
    Thank you, Morgano , worked perfectly
  11. #25
    Quote Originally Posted by morgano View Post
    Here your file
    Regards,
    pls i need pdf removal thanks
  12. #26
    Romania
    Try it
  13. The Following User Says Thank You to feketezsolt For This Useful Post:
    nokwueze (16th June, 2018)
  14. #27
    Quote Originally Posted by feketezsolt View Post
    Try it
    pls sir file is not good
  15. #28
    Jun 2013
    EU
    Your file DPF off.
    Program just flash.
    Regards,
  16. The Following User Says Thank You to morgano For This Useful Post:
    nokwueze (20th June, 2018)
  17. #29
    Your file DPF off.
    Program just flash.
    Regards,
    thanks i still need it on the second ecu
  18. #30
    Jun 2013
    EU
    Quote Originally Posted by nokwueze View Post
    See what i changed on first ecu and do the same on second.
  19. The Following User Says Thank You to morgano For This Useful Post:
    nokwueze (21st June, 2018)
