estwood68 (21st April, 2019)
Hello, colleagues .
SsangYong Actyon 2008 2.0L ***1060;***1077;***1102;
I use my old IMMOoff solution from Cyron.... and car start.
But there is C1170 (Vehicle coding error) in ABS after it.
I try to transfer ORI damp with fragments of IMMOofdamp, but there is wrong CS.
Can you help me with working IMMOof***1072; dump for this car?
http://yadi.sk/d/CvHK_UCh6akvM
http://yadi.sk/d/emk9PafL6al-y
The links on ori and immoof files
Try this solution (disconnect immo first), pass PM
Don't Forget Button
daniel fuscazu (25th July, 2018)
Thank You. It works.
IMMO lamp on with this solution, but car start and move ok.
hello
i have same probem with immo can yuo send me pass please
INEGMA (13th July, 2019)
Dump for kyron
can anybody help with immo off
Car start and work,thanks
here my Kyron dump. Please, immo off.
Fair comment, but if you put dumps up with out pass, at least the next person can work out what to edit.
imagine your stuck in a different town at a busstation, but nobody will give you a timetable, because your from
another town, your stuck.
but if your handed the solution/timetable you can at least get sorted on your own, without having to wait on others for months on end , if at all
darrenhyland (5th April, 2014), DOUGLASDL (29th July, 2014), eprombyxim (19th March, 2014), fitia (17th March, 2017), Gery (18th November, 2018), Hayssam1 (6th June, 2023), Meat-Head (8th March, 2014), Pali33 (8th March, 2014), Przemo1972 (8th January, 2017)
Hi guys.
So what is the actual casused of the C1170 code? I have it set by my cars ecu and searched for answers to what could be the actual cause and remedy for this code. The symptom is vore abs at all. No control lamp lighting up and no abs function.
Br
Kristofer
