Results 1 to 7 of 7
    Default Fiat Scudo 2007 2.0 HDI DFP Remove HELP need SID 803A
    Hi.
    I try to remove DPF from this ECU but after I remove same as Peugeot but it I have a problem after that with P0100 showing during drive and depolution fault...
    Maybee someone else have a working solution... I will be grateful...
    Thank You
    backup29bdd160gb.rar
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    P0100, perm fault; air flow meter signal open circuit or short to earth have u checked connection ... pollution fault dosnt always mean dpf
    Yes I checked Air Flow meter even replace to second one from other car... Still same story... 100km/h error P0100 I also give to professional check turbo charger and intercooler both OK... I test almost everything so I suppose this is problem with DPF Map...
    Really anyone... Any idea? Please...
    Meat-Head's Avatar
    Put orginal map back and try it
    did you unplug dpf sensors dtop ecu seeing them
    Yes I unplug DPF sensors... No errors in ecu... So everything looks OK, on original map it is difficult to check because ecu is in limp mode... Faulty DPF... And dpf sensors...
    Meat-Head's Avatar
    Use stalk function link on here youtube dpf solution. Uses resustotr on sensor
