HD combo switching off for no reason
Results 1 to 13 of 13
    Feb 2011
    Default HD combo switching off for no reason
    My HD Combo keeps switching off for no reason. its running on spiderbox and seems to worse on hd channels.
    any ideas?
    Sep 2008
    wondering on an old box if any caps are suspect inside.
  3. The Following User Says Thank You to cactikid For This Useful Post:
    scubadubba (5th August, 2013)
    Oct 2013
    Quote Originally Posted by scubadubba View Post
    any ideas?
    Mines still running on Carling...... And that has started switching off - it's worse when watching footie on HD channels. I also lose the sound a lot, thinking of replacing the box or updating the firmware.
    Jan 2009
    im getting the sameissue and cant find some channels like bt sport and that mu signal is high
    Sep 2008
    you do know channels move around dont you,have you done a new scan or looked in the sat bible?
    Astra 1N / Astra 2A / Astra 2D / Astra 2F / Eutelsat 28A / Eutelsat 28B (28.2?E) - All transmissions - frequencies - KingOfSat
    and dont think thats the end of it ,more to come
    DK Veteran vorlon2257's Avatar
    Sep 2011
    Vorlon Homeworld
    Quote Originally Posted by cactikid View Post
    Mine switch off 5 times yesterday within 20 mintues so opened the box tonight and 1 of the caps a 470uf 10v has bowed on the power board, I have already ordered some of Ebay tonight so will fixing it as soon they arrive.
    Sep 2008
    usually replaced with a higher grade than fitted,hopefully someone can advise what.
    Oct 2013
    Quote Originally Posted by vorlon2257 View Post
    Let me know how u get on....... This maybe something I need to do.
    I 'm not sure exactly what you mean but think its something like a dry joint on the circuit board - is that right?.
  10. #9
    Sep 2011
    Vorlon Homeworld
    Quote Originally Posted by Dwatto View Post
    have a look here..... http://www.digital-kaos.co.uk/forums...le-not-368837/
    should explain what we mean and what you have to do to fix it, there are a couple of pictures later on in the thread.
  11. #10
    Sep 2011
    Vorlon Homeworld
    Well replacement caps came today, and box is now fixed, so far everything seems to be running OK. Will report back if box reboots.
  12. #11
    Oct 2013
    I replaced C21 cap as it appeared to have swelled at the top, plugged the box back in....... Still rebooting the box and losing the sound!
    I have noticed that this happens when watching HD or premium channel- maybe I need to update the firmware, last updated 2010.
  13. #12
    Sep 2011
    Vorlon Homeworld
    There's Isn't really any new firmware out there for the Combo apart from Bytemasters I was bored one day conversion to a spiderbox. So updating the firmware can't be done.
  14. The Following User Says Thank You to vorlon2257 For This Useful Post:
    Dwatto (14th October, 2013)
  15. #13
    mine started doing this,bought a laptop cooling stand from the pound shop plugged into the rear usb and its been fine.
