Page 1 of 2 12 LastLast
Results 1 to 15 of 32
Hybrid View
    P&D's Avatar
    May 2010
    Default How to fix missing channels for the newbies
    If some of your channels say scrambled after a frequency change's the easiest way to fix them.....
    If you don't know how to update the box with Aj's or Sattv5 channel list (which are the best i have found so far ) via usb then follow the info below.....
    You need to find out which transponder the channel has moved to..... Plz see link below provided by cactikid thx mate
    or i'm sure others member will update us when this happens....
    For example.....
    E**N HD has just changed transponder from 12304-H to 11585-H so i guess your channel is scrambled ....
    This is the easy part ...
    Lets use the example above .......
    Press menu
    goto TP list.....(if you cannot enter your TP list because it's not high-lighted plz see post 4# below) Big thx to DW190
    Once in the TP list scroll up or down till you find 11585 (Or the transponder channel you want to scan)
    press the blue button (search)
    yes (press ok)
    Let the search run takes a few seconds....
    Exit Exit ...
    Bob's your uncle channel back....
    You will need to this with each channel thats missing......
    hope this helps
  2. The Following 60 Users Say Thank You to P&D For This Useful Post:
    Abdul83 (11th March, 2014), amjadhussain (10th August, 2013), andy91 (29th July, 2013), baadboy (8th January, 2015), bewal1 (2nd August, 2013), bigalex (21st October, 2013), bighank224 (7th October, 2013), captainglassback (11th September, 2013), chris31560 (15th February, 2017), chubbs9 (3rd August, 2013), cleggy53 (25th January, 2014), craigcaroletomliam (22nd October, 2013), deano16 (1st August, 2013), Dick Dastardley (10th May, 2014), djotay (9th August, 2014), eddiepara (13th March, 2014), fawada123 (25th October, 2013), gavwally (24th December, 2013), goldberg (10th August, 2013), jackjay1 (12th March, 2014), jackthelad662000 (29th January, 2014), janeye (13th November, 2013), jc69817 (17th March, 2014), leeant (6th August, 2013), maccas69 (16th October, 2013), markprice1984 (5th October, 2013), mguru (1st December, 2013), minelab (3rd January, 2016), mininfcc (20th August, 2013), Mysteriousguy (30th July, 2013), nicknak19 (30th July, 2013), Pezza321 (29th March, 2014), philfrommancs (6th August, 2014), plutox2 (7th October, 2013), protek (21st December, 2013), psychophil (30th July, 2013), RegVardy (2nd October, 2013), resonance (24th October, 2013), Rox13 (10th October, 2013), royal31 (24th October, 2013), samcanady (27th March, 2014), Saucy7 (2nd August, 2013), scooterboi150 (5th August, 2013), scotty1965 (30th July, 2013), seatonwills (31st July, 2013), SheWolf (27th March, 2016), silverlec (11th October, 2015), SLICK181818 (9th January, 2014), sohaillf (2nd July, 2015), Spartan50 (11th November, 2013), Striper Man (16th October, 2013), surapan (6th July, 2014), tailorvti (26th December, 2013), thanidar (4th August, 2013), votator (22nd August, 2013), wally6529 (5th October, 2013), willywizard (30th July, 2013), winmck80 (23rd February, 2014)
  3. #2
    Sep 2008
    bookmark this to pc or lappy its the bible for sat =when changes happen and that is very often.
    Astra 1N / Astra 2A / Astra 2D / Astra 2F / Eutelsat 28A / Eutelsat 28B (28.2?E) - All transmissions - frequencies - KingOfSat
  4. The Following 23 Users Say Thank You to cactikid For This Useful Post:
    Abdul83 (11th March, 2014), amjadhussain (10th August, 2013), baadboy (8th January, 2015), badboy1965 (23rd October, 2013), bigalex (21st October, 2013), bys561999 (25th August, 2013), cleggy53 (25th January, 2014), djotay (9th August, 2014), goldberg (10th August, 2013), joe516 (29th September, 2014), leeant (30th July, 2013), minelab (3rd January, 2016), mininfcc (20th August, 2013), Mysteriousguy (30th July, 2013), NuttyButty (28th October, 2017), Pezza321 (29th March, 2014), ppady (20th January, 2014), royal31 (24th October, 2013), samcanady (27th March, 2014), sparkie1234 (12th April, 2014), thanidar (4th August, 2013), wally6529 (5th October, 2013)
  5. #3
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by cactikid View Post
    It depends how quickly you want your channel back.
    That's a great site, but is often very slow to update channel changes. Can take days sometimes.
    If you think a channel may have changed frequency, & you want it back quick, you could do a complete sat scan, find where the channel has moved to, re-install the channel list you were using, then scan the TP that the channel moved to.
    ...Then let everyone on DK know where it is.
  6. The Following 2 Users Say Thank You to Hadron For This Useful Post:
  7. #4
    Oct 2013
    Astra 1N / Astra 2A / Astra 2D / Astra 2F / Eutelsat 28A / Eutelsat 28B (28.2?E) - All transmissions - frequencies - KingO**at
    This link does not work I'm afraid. Wether I am on my VPN or not. I need the listing to get PBS back.
    Life is not measured by the number of breaths we take, but by the number of moments that take our breath away.
  8. #5
    digicon's Avatar
    Jul 2009
    Quote Originally Posted by Fejinwales View Post
    Try This:
    http://en.kingo.f.s.at.net/pos-28.2E.php
    Remove the dots before the F and after the s
  9. The Following User Says Thank You to digicon For This Useful Post:
    fraggit (15th April, 2015)
  10. #6
    Oct 2013
    Thanks for the link. Unfortunately it does go to a site but not the one I need.
  11. #7
    digicon's Avatar
    Jul 2009
    same link found straight away:
    Astra 2E - PBS UK - 12110 - H - 27500 - 2/3
  12. #8
    P&D's Avatar
    May 2010
    Quote Originally Posted by gg1a View Post
    what does it mean when says failed when seaching transponders as im missing channels that i should get from client
    Helps to know what channels
  13. The Following User Says Thank You to P&D For This Useful Post:
    024U (12th October, 2013)
  14. #9
    P&D's Avatar
    May 2010
    Go into the menu....sat list.....press ok.....you will see a green tick top left.... exit.......TP list back
    http://www.digital-kaos.co.uk/forums...0/#post2041582 thx to DW190
  15. The Following 7 Users Say Thank You to P&D For This Useful Post:
    Abdul83 (11th March, 2014), deano16 (1st August, 2013), minelab (3rd January, 2016), randersod (6th August, 2013), scooterboi150 (5th August, 2013), scotty1965 (30th July, 2013), walf (30th July, 2013)
  16. #10
    digicon's Avatar
    Jul 2009
    Ok Made this a sticky and removed Posts that are not relevant.
    Dont forget no need to post Thanks use the Buttons bottom right 'Like' bottom left 'Thanks' to the Original Posters
  17. The Following 3 Users Say Thank You to digicon For This Useful Post:
    Hadron (2nd August, 2013), Springer100 (2nd August, 2013)
  18. #11
    May 2014
    If you've followed the suggestions above and are still missing channels, try the following.
    So very quickly, I had carried out all of the suggestions and procedures from the thread (TP List search, downloaded the latest AJ lists etc) and I was still missing a number of channels. I was fairly sure it was not an issue covered above so I tried reformatting my USB (saving all of the files off it first). I plugged it back into the box and for some reason (I probably did something wrong!) it wasn't being recognised by my box. So I copied the files onto a different USB, upgraded the relevant ones and the missing channels were now displaying.
    Seems obvious now but try upgrading with a new USB
  19. #12
    Jul 2014
    I wish I had seen your post before going down another route which has resulted in having no channels
  20. #13
    Jun 2014
    I have re-done my f5s box several times and I get all free to air channels but my $ channels just keep saying scrambled don't know what to do ive e-mailed the guy who sold me the box but aint heard a thing back please help me get my channels back
  21. #14
    digicon's Avatar
    Jul 2009
    @katoy,
    I am afraid you will receive no help in trying to get any Scrambled channels back its clearly written in the Forum Rules.
    All i will say is Try Google
  22. #15
    Apr 2010
    Can someone help me i have an openbox v8s, i have managed t get to the TP list and can see the channel frequency but when i press the blue button it don't seem to be doing anything.
