Moyy0617 (18th January, 2024)
Hello guys!
I have here ECU from Kangoo 1.2 16v 2001 year. I need immo off .... This is half hybrid ecu and i don't find eeprom ... Maybe is that ST 3nv04d 8pin.
Is it possible to do immo off ?
I also have emulator if i will be need it. But first i have to erase immo form eeprom. And witch wire must i cut then
If that is 95160 is there any pinout how can i read that ?
Ok i read this 95160 .... i soldier wires on and read with xprog ... can someone made that immo off?
Hello, you dump off, not tested, post result
Ok when i put file in witch wire shuld i cut ?
And can you tell me if you do that wit obe of your programs or you erase it by your own?
Yes it is working !
Don't forget to put together L4 and M4 and cut L4 from other side ...
3R1 (28th June, 2014)
Ok i will explane. You must be wery careful when you scratching gel down. Every pin have "big" test point and it is room enough for soldering tiny wires. You have to have alot of skills with soldering and you must do over microscope. Also you soldier on 370 degrees not more or you will burn small golden pads on ceramic plate. You must also watch on golden wires that you will not touch with solder iron or soldier needle that will burn golden wire instantly and we dont wanna do that :-)
Ok you must know that pin 7,8 are soldier together. So you need 7 wires :-)
Also you must watch that you will not made short circut between wires. You must be wery calm.... No wife arround or kids when you operating that :-)
Ill also attach pictures!
P.s. Yes those files are correct and working ;-)
Don't forget to thanks
dadal (19th January, 2017), Darkman4732 (12th January, 2024), DOUGLASDL (31st July, 2013), tinky (20th June, 2017)
thank you for sharing mate
