Page 21 of 76 FirstFirst ... 1116171819202122232425263171 ... LastLast
Results 301 to 315 of 1139
  1. #301
    Sep 2012
    Hello, sorry if this is te same thing everyone is asking but after 4th Oct update I can't get RACING UK or AT THE RACES.
    Everything else I use seems fine. I have 3 other people I know with the same issue.
    could anyone offer a solution or even reason??
  2. #302
    Mar 2013
    Hi could you please add in Setanta ireland to the Sports Section it only shows up in All Channels at the moment and was in sports until latest list
    Thanks for your time
  3. #303
    Oct 2013
    This has sorted out a newbie nicely. Followed skytv5's instructions with the favourite settings and i worked a treat
  4. #304
    May 2013
    Quote Originally Posted by out7aw View Post
    can anybody tell me the difference between the 4 channel lists uploaded? i am not sure which
    one i need.
    Full HD:
    BBC1, BBC2,ITV1,Channel 4,Channel 5 at channels 101-105 are the HD Versions
    the SD Versions are at BBC 1 SD 141, BBC 2 SD 142, ITV1 SD 178, Channel 4 SD 230, Channel 5 SD 171
    Full HD No Adult:
    Exactly The same as Full Hd except all adult channels have been removed
    Sky HD:
    BBC1, BBC2,ITV1,Channel 4,Channel 5 at channels 101-105 are the SD Versions
    the HD Versions are at BBC 1 HD 141, BBC 2 HD 142, ITV1 HD 178, Channel 4 HD 230, Channel 5 HD 171
    Sky Hd No Adult:
    Exactly The same as Sky HD except all adult channels have been removed
    Quote Originally Posted by kenchov View Post
    could someone tell me where the updated channel list is?
    Sorry forgot to put the link at the bottom of the post
    http://www.digital-kaos.co.uk/forums...1/#post1980897
    Quote Originally Posted by Kristo32 View Post
    I will take a look in a bit at the list as those channels are working fine here, it could be something as simple a
    me using the wrong version of the channels (commercial) instead of domestic ones
    UPDATE: there is no commercial versions of these channels and the details are correct for the UK, there is only an irish alternative to attheraces and if I swap that channel out it would cause more problems than it solves.
    Quote Originally Posted by colinwallace View Post
    Yep no problems, I must have accidently forgot to add it back there
  5. #305
    Quote Originally Posted by sattv5 View Post
    There's still 6 more transponders to shut down between now and the 10th october.
    I avoided using any of them transponders when updating the channel lists so we don't have to worry about it
    Any chance you could post the 6 transponders that should be avoided due to shut down, or direct me to where this info is?
    Thanks again.
  6. #306
    joe516's Avatar
    Mar 2008
    manchester
    Quote Originally Posted by bbb_uk View Post
    Thanks again.
    11469H off
    11488V powered but no channels
    11508H off
    11527V powered & carrying 10 services
    11604V off
    11623H powered & carrying 13 services
    11662H powered & carrying 13 services
    11681V powered & carrying 14 services
    12523H off
    12523V powered & carrying 30 services
    12560H powered & carrying 6 services
    12560V powered & carrying 19 services
    12607H powered & carrying 16 services
    12607V powered & carrying 31 services
    12643H powered & carrying 11 services
    12643V powered but no channels
    information given is to be used for educational purposes only
    Don't Forget To Say Thanks If You Like My Post
    IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
    If It Ain't Broke Don't Fix It
  7. The Following 3 Users Say Thank You to joe516 For This Useful Post:
    bbb_uk (5th October, 2013), BMWcare (5th October, 2013), oscarjohnboy (5th October, 2013)
  8. #307
    Apr 2013
    i can't get Heat or Magic TV channels ..363 and 364... says no signal.. has it moved or is it off ... was there a few days ago
  9. #308
    DK Veteran mahrkpat's Avatar
    Jun 2012
    Need to update channel list lot of channels are moving about maybe a week or more before things settle down again.
  10. #309
    Quote Originally Posted by genam View Post
    As mahrkpat has said, lots of channels have changed.
    Mine still works on transponder 11221/H. To double check your transponder click info twice on the Heat or Magic channel.
    If the first half of your transponder doesn't match above then download either AJs or Sattv5 channel list (see stickies on this thread) depending on which channel list your currently using which it sounds like it's Sattv5's.
  11. #310
    May 2013
    Any chance you could post the 6 transponders that should be avoided due to shut down, or direct me to where this info is? Thanks again.
    10979 V 22000 >>>>>>>>12515 H 22000
    11082 H 22000 >>>>>>>>12522 V 22000
    11112 H 22000 >>>>>>>>12552 V 22000
    11141 H 22000 >>>>>>>>12581 V 22000
    11156 V 23000 >>>>>>>>12574 H 23000
    11171 H 22000 >>>>>>>>12545 H 22000
    (red ones are closing down the other ones are where they have gone)
    The channels from these are complete duplicate transponders, instead of moving each individual channel just change
    the details of the transponder in the channel list and then theres only 6 changes to make
    I will move the Heat & Magic TV Channel to one of the new transponders, although they still work on the frequency
    there on (11221 H). They are both on 3 different transponders at the moment still.
  12. The Following User Says Thank You to sattv5 For This Useful Post:
    bbb_uk (6th October, 2013)
  13. #311
    May 2013
    prime time returns no signal
  14. The Following User Says Thank You to sparky18779 For This Useful Post:
    sattv5 (7th October, 2013)
  15. #312
    May 2013
    I have checked again and the channels on the other transponders are the radio versions of the missing channels, so i am not sure why they are not working for you on the existing frequencies as they are FTA channels anyway
    Moved Frequency Channels Updates 06/10/2013
    Primetime (Channel 498) Changed Frequency to 12640 V 22000 (sid 55245)
    Setanta Ireland (Channel 423) Channel was missing from Sports Favourites
    Premier Sports (Channel 428) Channel was missing from Sports Favourites
    ***panded Tv (Channel 931) Changed Frequency to 12581 V 22000
    ***cess (Channel 923) Changed Frequency to 12640 V 22000 (sid 55248)
    Sukh Sagar (Radio Section) removed as Duplicate
    Capital XTRA (Radio Section) removed as Duplicate
  16. #313
    Aug 2008
    I don't usually post or ask for much as I can usually work it out for myself! Anyway, after updating to the latest sattv5 list I've noticed that the all channel favorite seems to have disappeared and i'm now finding it a nightmare to find anything due to not having a full sky number listing! Is there any chance that this can return please as I really miss it and don't use the other favorites! Thanks in advance.
    EDIT:- Don't worry, I got it now, I was thinking about Pellonet's list. I'd completely forgotten who i'd got the original list from until now! Anyway, I read the main list page and found out what to do so for anyone else who's lost you need to click on OK, then click the red button and select all in the little menu that pops up (It will look like the channels have disappeared but don't worry, they haven't!). Then when you exit out of the lists to go back to viewing you'll have a SKY ordered list to work with!
  17. #314
    Senior Member tony2803's Avatar
    Jun 2008
    sky living+1 and sky livingit+1 am I wrong or are these two channels not in the correct sky order.as living+1 is not on 123.
  18. The Following User Says Thank You to tony2803 For This Useful Post:
  19. #315
    May 2013
    Quote Originally Posted by tony2803 View Post
    Sky Livingit + 1 on (Channel 223) is correct
    Sky Living +1 (should be on 123) Missing channel accidently duplicated sky livingit +1 here
    Will update with other updates later, just waiting to see if any other changes today.
