Page 2 of 76 FirstFirst 12345671252 ... LastLast
Results 16 to 30 of 1139
  1. #16
    May 2013
    oh right, ill give it a go! cheers
  2. #17
    it`s a great list but bbc1,bbc2,itv1,channel 4 and channel 5 are only sd channels. if hd could be added it would be much better
  3. #18
    Oct 2011
    If this keeps getting updated then this thread deserves a sticky, or make a new thread with all the junk gone
  4. #19
    Jun 2013
    Quote Originally Posted by sattv5 View Post
    Moved Frequency Channels updates 29/6/2013
    Bt Sport 2 Channel 446 Moved frequency
    Trace Sports Channel 442 renamed Trace Spt Stars
    I have added 2 more Channel lists which are Full HD ordered and have the following Channels higher up the EPG as
    requested
    BBC 1 Channel 141 Moved to Channel 101
    BBC 2 Channel 142 Moved to Channel 102
    ITV Channel 178 Moved to Channel 103
    Channel 4 Channel 230 Moved to Channel 104
    Channel 5 Channel 171 Moved to Channel 105
    Great list. I think it should be added as a sticky. Im using this all the time now. fast updates and great being in sky order.
  5. #20
    Sep 2010
    Default channel list
    requested
    Your channel list is fantastic, definitely the best around. Keep up the good work
  6. #21
    digicon's Avatar
    Hi All,
    As Requested sattv5 Channel list is now a sticky, so lets try and keep it organised by not asking silly questions and that members will then be able to find the latest channel list easier instead of trawling through pages of thanks posts.
    Please remember to use the Thanks and Like tags instead of posting.
  7. #22
    Dec 2010
    Thank you so much!! Iv made lists before and i appreciate it have being done!!
    Was going to do it the long way, rescanning old channels
  8. #23
    Member preditor's Avatar
    Nov 2011
    AT HOME
    Hi, what's the difference between the HD ordered and the FULL HD ordered ? Thanks
    Discussions about cardsharing are not allowed...
    Discussions about hacking or modifying cable company equipment will be removed.
  9. #24
    May 2013
    The Sky HD Channel list has BBC1, BBC2, ITV, Channel 4 & Channel 5 (Channels 101 to 105) as the SD Versions
    The Full HD Channel list has BBC1, BBC2, ITV, Channel 4 & Channel 5 (Channels 101 to 105) as the HD Versions
    everything else is the same.
  10. #25
    Jun 2013
    Can I individually add the changed frequency channels instead of updating the list all the time?
    Sent from my GT-I9305 using Tapatalk 4 Beta
  11. #26
    Aug 2008
    any irish channels ont his for ireland like rte 1 on 101 rte2 on 102 and so on?
  12. #27
    May 2013
    Wow put you and aj together and we have an excellent team of people who can really make beasts of lists
  13. #28
    May 2013
    Quote Originally Posted by bb5 View Post
    The lists are set up for the english version of Sky but the Irish Channels can be found on the following numbers, as well as having there own category in the favourites list.
    Channel 1065 RTE One
    Channel 1066 RTE Two HD
    Channel 1067 RTE Two
    Channel 1068 RTEjr
    Channel 1069 TV3
    Channel 1070 TG4
    Channel 1071 3e
    Channel 1072 UTV
  14. #29
    Jul 2013
    hi sattv5, have just updated box with lastest tp prog , I noticed that sky sports ashes is now in sd form.
  15. The Following User Says Thank You to ts398im For This Useful Post:
    sattv5 (4th July, 2013)
  16. #30
    Jul 2013
    Thanks - will give it a go
