joe516 (30th March, 2017)
And some other channels, PLEASE READ THE POST THAT HAS THE CHANNEL LIST ATTACHED for more details.
http://www.digital-kaos.co.uk/forums...=1#post2992872
If you need help installing channel guides or have a problem, take a look at my video guides
https://www.youtube.com/playlist?lis...GHAAdpsKXqtadC
Any updates on the the sky sports and the box office yet thxs
30/03/2017
I have updated the CWAITE Sky numbered channel list, with the following changes, there is also a list which excludes the Adult Channels
New Vision TV Replaced ARY QTV on 804
SEE TV added to 862
I have swapped some of the non working channels for working Irish Alternatives
Living +1 on 122 is the Irish Version
Comedy central extra on 129 is the Irish Version
Sky Sports 4 on 404 is the Irish Version
Sky Sports News HQ on 405 is the Irish Version
We now have an ALL Channels section in Favourites which contains all of the channels together (except the Non working HD channels and the test section)with no gaps, to get to this Press FAV on your Satellite Remote then scroll up or down to the last Favourite Section (labelled Fav Group 32 or ALL CHANNELS).
To Get back to the Sly channel numbers Press SAT LIST on your Satellite Remote then press EXIT, your channels will be back to the usual Sly numbers (i.e. BBC ONE on 101, BBC TWO on 102, ITV on 103 etc)
At the moment there are reports that a few channels are not clearing and showing SCRAMBLED this is NOT a fault with the channel list its happening to all non Offical $ky boxes due to a change in the Encyption implemented by $ky
Channels that are known to be not clearing are
Sky Atlantic (+1 OK)
Fox +1 (Fox OK)
TCM (+1 OK)
Eurosport 1
Eurosport 2
Sky sports box office
Adult Channel
Playboy
Climax
Ex GF
Living +1
Sky Sports 4
Sky Sports News HQ UK & Ireland
Sky Sports 1 Ireland
I have put these versions below in place of the normal UK version of the channels so these should work on their normal $ky Channel Numbers
Comedy central extra Ireland
Living +1 Ireland
Sky Sports 4 Ireland
Sky Sports News HQ (Alternative Version)
AT THE CURRENT TIME NO-ONE KNOWS HOW TO GET THESE CHANNELS BACK, SO NO-ONE KNOWS HOW LONG THIS WILL TAKE TO FIX OR IF IT WILL EVER BE FIXED, BUT ITS VERY LIKELY THE MORE CHANNELS WILL STOP WORKING SOON.
alphatango (1st April, 2017), harveyboy73 (31st March, 2017), joe516 (31st March, 2017)
They wont be back SD channels are a thing of the past now time to move on .
Read the v9s is working fine on those channels so not over yet.
Having to watch Eurosport on kodi
Seen this on another forum .
Not a huge contributor on here, but am a constant user to keep updated and abreast of things, I'm not a server owner or a programmer etc, just an enthusiast who read the old threads earlier and didn't respond to any of the guesswork that was going on as basically that was all it was, uneducated guesswork.
I know there was mention above of not posting messages regarding "My mate said this or that" etc, but I do actually know two people personally who are involved with Oscam work and programming, one of them whom I know from my university days is directly involved with the upkeep and admin at the site "Streamboard" also, there's no info more up to date than the info he has access to and that is fact.
In an earlier thread that has since been deleted there was an actual link to Streamboard, anybody who checked it would have seen that it went into the actual technical side of what was happening, not random guesswork, having had a conversation with somebody directly involved I can confirm a few things, everything that I'm about to write will be updated and confirmed through Streamboard in due course once everything has been finalized, the only reason I'm taking the time to do this is because of the guesswork and scaremongering that's been going on, although unintentional that's pretty much all that's happened since yesterday so some facts might help put some folk at ease to an extent.
The facts as to what is actually happening were touched upon in the above mentioned link and that is that there is nothing within the Entitlement Control Message (ECM) that is affecting things right now, so all talk of ecm changes are just nonsense, as is transponder talk.
The problem exists within the CW (Control Word)....The actual encryption data itself
Now this is where the technical side of it went way over my head during my conversation, but the laymans terms that I got was that the encryption has not changed in the same way it did for HD or for the same way it did with Sky Italia, the encryption is compatible with existing Sky cards, including the old white 09's which is where local cards and shared cache's get the required data to make card sharing possible, so that also makes the talk of changing over Thompson Receivers to Sky +HD nonsense also, its completely irrelevant.
What they have done is quite clever apparently but it will 100% be worked out, the changes that will be required to be made will all be within the "oscam.config" which is basically the standard configuration file that servers use to run and make this all possible, so server owners will be getting access to an updated config file once completed and the missing channels will be back.
This is as close to the horses mouth as you will get and I have been told categorically that this is absolutely NOT the end of cardsharing as we know it and when the config is complete and uploaded things will continue as they were once servers have been updated to the new config.
There is a but though and that is the reasoning behind what has happened the last few days, the general feeling is that Sky were testing a few channels to see what the result was, that unfortunately is not true, Sky and anybody with a certain level of understanding of encryptions would know that no test is required, the results of the changes that were made are set in stone and known before they were put in place therefore there is no test required or needed.
That is where the but comes in because what has happened is fixable with a configuration change, Sky and the programming engineers working with Sky know that just as much as the guys who deal with oscam, they know its fixable and can be worked around, so the actual reason behind it is a mystery.
Its not just to disrupt or to annoy, that much is clear, but the real reason is unclear at the moment as the changes they have made don't really relate to anything they can build on long term as once worked around that's it, it cant be implemented into a different part of the whole procedure so its not clear why they did it or what the overall goal of it was but its obviously something much bigger and more complex, whether its something that could happen next week or next year nobody knows, but its clear that some serious thought and investment has been put in to this and its one of the biggest changes or moves that Sky have made to in a long time, so the general feeling from someone directly involved is that something much bigger is on the way, but as above the timescale is not known.
Sky have obviously always taken it seriously and attempted to stop it but it looks as though they have upped the effort on it and are seriously taking steps to put an end to it long term, or at least until the technology to work around it comes to light.
I know some people on here will no doubt rubbish everything that I have put down here because I'm not directly involved with oscam or servers and because I'm not a TK Veteran etc etc, but what I've put down will be available through streamboard in due course and a lot of it already is there to read up on, so please take the time to research a little into the technical facts of what is going on and with what I've tried to explain here and hopefully I've helped put some minds at ease a little.
Anyone got sky frequency number for TCM 12148 27500 doesn't work anymore?
Everything on 12148 H 27500 is currently not clearing
Channel id, # channel name
1813, # ComedyXtra
1726, # Eurosport 1
1841, # Eurosport 2
1791, # FOX+1
1412, # Sky Atlantic
1414, # Sky Atlantic
2205, # Sky Living+1
1314, # Sky Sp NewsHQ
1319, # Sky Sp NewsHQ
1311, # Sky Sports 1
1309, # Sky Sports 1 RoI
1322, # Sky Sports 4
1344, # Sky Sports 4
1364, # Sky Sports 4
1034, # SkySpBoxOff
5605, # TCM
Channels currently available on other transponders
2709: # ComedyXtra
4335: # Sky Living+1
1325: # Sky Sp NewsHQ
1301: # Sky Sports 1
1324: # Sky Sports 4
TCM+1 is ok m8 11264 27500 H
information given is to be used for educational purposes only
Don't Forget To Say Thanks If You Like My Post
IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
If It Ain't Broke Don't Fix It
Hadron (5th April, 2017)
