Originally Posted by
sattv5
Moved Frequency Channels Updates 04/11/2013
Lifetime HD (NEW) Channel number 1077 moved to EPG Channel number 156 (11719 H 29500)
Lifetime (NEW) Channel number 1078 moved to EPG Channel number 197 (12285 V 27500)
Lifetime +1 (NEW) Channel number 1079 move to EPG Channel number 291 (12581 V 22000)
Bio (channel number156) removed as letf astra 28a
UTV HD (NEW) added to EPG channel Number 1072 (11053 H 22000)
PLEASE NOTE: Can you please remember to Delete your existing channel list before Updating
Can anybody tell me the difference between the 4 channel lists uploaded, I am not sure which
one i need ?
Full HD:
BBC1, BBC2,ITV1,Channel 4,Channel 5 at channels 101-105 are the HD Versions
the SD Versions are at BBC 1 SD 141, BBC 2 SD 142, ITV1 SD 178, Channel 4 SD 230, Channel 5 SD 171
Full HD No Adult:
Exactly The same as Full HD except all adult channels haveLifetime HD (NEW) Channel number 1077 moved to EPG Channel number 156 (11719 H 29500)
Bio (channel number156) removed as let astra 28a
UTV HD (NEW) added to EPG channel Number 1072 (11053 H 22000) been removed
Sky HD:
BBC1, BBC2,ITV1,Channel 4,Channel 5 at channels 101-105 are the SD Versions
the HD Versions are at BBC 1 HD 141, BBC 2 HD 142, ITV1 HD 178, Channel 4 HD 230, Channel 5 HD 171
Sky HD No Adult:
Exactly The same as Sky HD except all adult channels have been removed
When wanting to type in a channel e.g 101 or 401 why do i get "no such channel" ??
Press the ok button, then press the red button then select All.
Then when you come out of that press 101 or 401 and hey presto you should then get the full list of channels.
What boxes will this list work on ?
The Channel List is suitable for Openbox/Skybox S9, S10, S11, S12, M3, X3,F3, F3s F4, F5 & F5s
My Favourites are all wrong since I loaded your list how do i fix them ?
The way to get The favourites under the correct headings is to load the default Database:
On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Don't make any choices at the menu)
The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct order
Your channel list hasn't installed when I press info there was a comment like " file not found" or something similar ?
Try The following:
Check you have unzipped the channel list from the zip file
Make sure that TP_Prog.dbs is on the root of your flash drive
Redownload the list using a different web browser
What's the favourites.jpg for in the zip file ?
It's just to show you what your favourites list on your box should be labelled like
