Page 4 of 76 FirstFirst 1234567891454 ... LastLast
Results 46 to 60 of 1139
  1. #46
    Member durasoft's Avatar
    Aug 2008
    Quote Originally Posted by satboxman View Post
    have up dated with new list but cant get
    ss 1 hd
    ss ashes
    ant a lot more just says no signal but box works ok on other channels I'm using a f5 if it was tuner then would all channels be no signal not sure if they have changed the frequency agen to crack us all up
    Hi satboxman, Just worth a try. Go to Menu then Installation and select Satellite List, Press Red Button to Edit your entry, I know by changing your LNB Freq can sometimes help.
    If your on Universal (9750-10750) try Universal (9750-10600) then exit and save. See if that helps in any way. I know BBC1HD and ITV1HD work on both, BUT SlySports1HD does'nt.
    Just a thought thats all m8 :-)
    Regards Tony
    Humax FoxSat-HDR
    Great HD/SD Box with 500GB HardDrive
    Manhatton HH-120 42E-30W
    Triax 88cm 0.3db
    SKYBOX F3
    HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
    Intel Core i7 2600K@4.2GhZ
    MSI R7970 Twin Frozr Boost Edition
  2. #47
    Aug 2012
    Great channels list mate, appreciate your hard work.
    Please keep this up-to-date, and I can see this becoming very popular here.
  3. #48
    Jan 2013
    hi lads
    every time i try to put new channel list onto my skybox f3 i keep getting message file not found,this is what i have done,deleted old channel list and downloaded June Sky Ordered TP_Prog.dbs extracted it and put in onto root of USB(FAT32) put it into box went to tool, upgrade by usb selected music file, keep DBS and setting NO, select and upgrade TP_PROG.dbs selected and then upgraded it and when i check it says file not found, when i put my old channel list back on it goes on no problem am i leaving anything out do i have to do a blind scan before i put new channel list on, any help please
  4. #49
    May 2013
    hi just looking for a little help, ive upgraded my F5 skybox to this channel list from another one. i deleted the old one and put this one on. i got all the channels but i dont have them with sky numbers like movies being 301, instead its still under favorites - movies - 3. have i done something wrong, cheers.
  5. #50
    Aug 2008
    Quote Originally Posted by wezpic View Post
    Hi Wezpic,
    Press the ok button and when it shows you the channels press the red button to show ALL
    Hopefully that will take you out of viewing the favs and put you into being able to select 301 movies or 401 s-sports 1
    Hope that helps m8.....Tony
    Humax FoxSat-HDR
    Triax 88cm 0.3db
    SKYBOX F3
  6. #51
    Newbie navdsingh's Avatar
    Apr 2011
    Birmingham
    I have just updated my channel list but sly movie channels are not working expect showcase need help..... or am I doing somthing wrong??
    Sent from my GT-I9100 using Tapatalk 2
  7. #52
    May 2013
    Durasoft (Tony)
    That did the trick thanks.
  8. #53
    Jul 2013
    Thanks for this works great
    although I thought I did something wrong when I saw 0-100 blank, then realised that's how it normally is .
  9. #54
    What editor do you use to create these lists?
    Sent from my Nexus 4 using Tapatalk 2
  10. #55
    Apr 2013
    hi guys, sorry if this is in the wrong place. How do I do a channel rescan as I see some of the channels have moved frequency. Also will this remove the gift. Thanks
  11. #56
    P&D's Avatar
    Quote Originally Posted by mezzyg View Post
    I use STBHDEditor
  12. #57
    Jul 2013
    Quote Originally Posted by keeran View Post
    No need to do a scan, look at post no.57 on this thread.
  13. #58
    Oct 2011
    Nice one keeping the list up to date, maybe you could keep the first post in the thread updated with the latest list and info, it will keep it more organised like AJ's thread and a lot easier to answer questions and see feedback
  14. #59
    Jan 2009
    Edit: im an idiot the non adult ones are actually non adult
    Thanks!
  15. #60
    Aug 2012
    This is really a great job well-done Sattv5. But channel 329 is not showing. And what is best way to skip the blank channels?
    Thanks for the channel list.
