P&D (17th March, 2016)
are they moving channels alot recently? seem to have lost sky sports 5, cartoon network & +1, boomerang, nickelodeon to name but a few.
getting no signal on all these channels which i assume means they've moved trans?
Why not make your own channel list ?? just a thought . thats all part of the fun of this hobby
Hi cwaite, just wanted to ask a question regarding your list, i am currently using aj,s list and was wondering if i have to do a factory reset first before using the cwaite list?
Many thanks in advance
Because CWAITE's list & AJ's lists use slightly different favourite headings, you might find that when swapping from one list to the other, the headings for a few categories might be wrong.
In that case you will need to do a "factory settings" after installing the new list.
To get the headers to show correctly, you need to reset your box back to Factory settings after you have installed the latest channel list (menu > tools > factory settings). A message will appear to say that it will erase the channels. Select Yes. A pop-up menu will appear with options to erase other files. DO NOT SELECT ANY OF THESE. Press the blue button on remote. Wait a few seconds for the data to be saved.
You should now have the favourites labeled correctly.
Put the box into standby & then back to ON. (You have to do this now before making any of the changes mentioned below, otherwise they will revert back).
Depending on which model of openbox/skybox you have, these menu options may need to be reset...
Check summer time is set correctly.
EPG default setting will be "satellite"
If you have your channel list layout set to "three" it will reset back to "whole" in the M/P > GUI config setting.
Check DHCP is set to ON
Check Local time setting is still on UK
Subtitles will be set to ON
Network Local Settings may be hidden on older models (press 6666)
camds setup may be hidden in Network Local Settings (press 6666)
Volume will be reset to half way
PIN might have been reset to 0000 (not sure about this, as I never change it).
looks like you have the latest list.
If you have any other satellite boxes coming off your dish then try unplugging them from the mains ( do not just put the other boxes in standby) if the channels return with the other boxes disconnect from the mains then you need a no signal fix cable from eBay if you don't have any other boxes connected then you may need to get your dish alignment and cabling checked.
I'll try run the update again and see what happens s first. It's only a few channels but sp5 is the main wwe channel at the mo which annoys me .
Cheers dude.
