Cwaite Sky Numbered Channel List **Discussion** Thread
Page 1 of 76 1234561151 ... LastLast
Results 1 to 15 of 1139
    Apr 2013
    Default Cwaite Sky Numbered Channel List **Discussion** Thread
    That sky list is great...formed a fantastic base file for me to do my regional tweaks....THANKYOU
  2. The Following 4 Users Say Thank You to genam For This Useful Post:
    iceman (6th August, 2015), liamwebbo88 (1st May, 2017), stefmc26 (19th May, 2017), xbtman (21st February, 2015)
  3. #2
    Senior Member tony2803's Avatar
    Jun 2008
    Quote Originally Posted by tony2803 View Post
    great channel list,works great on my f3.thanks
    I can honestly say that this is the best channel list I have come across, (dogs dodahs)
    set up to my region and set blank channels to skip my f3 is now working like a sly hd box
    once again thanks.
    Dec 2012
    Its a great list however - I would have preferred the HD channels would have priority over the non HD channels in the Sky list and maybe have a non adult variant of the list too
    Thanks to the original poster.
    Junior Member Marmite123's Avatar
    May 2013
    Is Disney Movies now included in this list ? Thanks.
    May 2013
    Quote Originally Posted by Marmite123 View Post
    Sky Disney HD Channel 305
    Sky Disney SD Channel 332
    May 2012
    Quote Originally Posted by soggykipper View Post
    That's not good than if Asian channels are not in order. please can you upload full uk channel list like bbc1 101 Geo news 825 ump movie 797
    Why not have a go at moving them yourself then you can have them just where you want them.
    All of the channel list are done as a general list to suit most needs.
    You can please some of the people some of the time but not all of the people all of the time. Thats how the cookie crumbles.
  8. The Following User Says Thank You to DW190 For This Useful Post:
    bys561999 (14th September, 2016)
  9. #7
    hi, when I ahh new channel list to f3 box al favs mixed up ie, sports under kids fav music under hd etc etc
  10. #8
    Jun 2013
    u need to reset to factory setting to get the correct fav channels list line up
  11. The Following User Says Thank You to bulldog147 For This Useful Post:
  12. #9
    Mar 2013
    once again thanks.
    How do you set blank channels to Skip? Thanks.
  13. #10
    Member durasoft's Avatar
    Aug 2008
    Quote Originally Posted by AndyX View Post
    Hi Andy,
    This is regarding SkyBox F3 buddy.
    1. Goto Menu then Channel Edit.
    2. Tick the blank channel's you want to skip.
    3. When done select the bottom Icon on the right called "Skip"
    4. Then press exit and confirm "Are you sure to save" YES.
    5. Reboot box and Done
    You can now Skip the Blank channel's as you cycle through your listing's.
    Cheer's Tony
    Humax FoxSat-HDR
    Great HD/SD Box with 500GB HardDrive
    Manhatton HH-120 42E-30W
    Triax 88cm 0.3db
    SKYBOX F3
    HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
    Intel Core i7 2600K@4.2GhZ
    MSI R7970 Twin Frozr Boost Edition
  14. #11
    Jun 2013
    Quote Originally Posted by bulldog147 View Post
    my favourites were all messed up but done as this post said and all the favourites were as they should be
  15. #12
    Jun 2008
    Quote Originally Posted by sattv5 View Post
    New Channels & Moved Frequency Channels updates 27/6/2013
    Cruzr (Now on Sky EPG moved to Channel 943)
    Box Office HD 2 channel 702 removed as no longer in use
    Weddingtv Channel 1072 removed as left Astra 28a
    News 18 India (not on Sky EPG yet) Channel 1072
    Other Channel list ammendments:
    All favourites now in order and updated (you may have to change labels on them to reflect this)
    (See favourites List included in zip)
    MTV Channels correct Audio Pids Used
    HD Movie Channels correct Audio Pid set to Defaults
    Blank channels now skipped when scrolling through channel list
    TP_Prog.DBS file extension changed to lower case (.dbs)
    it cannot get any better than this,this d/k member should be d/k knighted for his work on his contribution on this subject.great thanks, Sir sattv5.
  16. The Following User Says Thank You to tony2803 For This Useful Post:
  17. #13
    May 2013
    Does this list work on a skybox f5? if not, how come it works on a f3, whats the difference?
  18. #14
    Dec 2012
    A great list - I prefer this over AJ's Sky List, One improvment would be that channels at the start 101-105 are HD versions but then it wouldnt match Sky EPG
  19. #15
    Mar 2013
    Quote Originally Posted by sickswan View Post
    Yes I'm using it on a F5 and it works great.
