AUDI A3 2010 8P0920932G micronas flash damadge after mileage adjust try
Results 1 to 15 of 25
    felix_fetche's Avatar
    Baia Mare
    Default AUDI A3 2010 8P0920932G micronas flash damadge after mileage adjust try
    hi,
    using the blue chinese tool "super vag-can" trying to adjust mileage the dash restart and remain
    with blank display and steppers frezed at last value without returning to zero, no LED`s on, without life.
    finaly after many radings i succeed to read and verify well the flash from MICRONAS. eep as well.
    please someone do repair them to bring the dash back to life.
    is audi A3 made in june 2010 VDO H01 vag-nr: 8P0 920 932 G.
    or please give one good flash file, i will write into dash then try again to destroy to see what is happening,
    than roll-back action threating the ori flash with the hope to obtain the original state.
    booth 24C32 and 29LV800 of the CDC3217G (inside mounted ID`s 00010000 and 000122DA) are attached here.
    thanks !!!
    A3_8P0_y2010_micronas+24C32.zip
    Landetos's Avatar
    Mar 2013
    Inside EnigmaTool
    get somebody with enigmatool...I bet that it will fix your problem
    Baia Mare
    is not connecting, returns error 09 (no communication).
    Baia Mare
    let me know the procedure.
    my coleague owns enigma, what to tell him to do or to ask in order to reflash the cluster?
    update for the tool and flash file for my dash P/N ?
    Baia Mare
    solved,
    very easy, copy<>paste two lines from another flash, and rebuild the third one with orig P/N from dash sticker.
  6. The Following User Says Thank You to felix_fetche For This Useful Post:
    HeXeN (29th February, 2016)
    which lines ? which flash ? From same dash part number or different dash part number ?
    Nov 2011
    friend and friend
    Default help please
    good afternoon friend can help repair the dash, died when I change km plus super vag k
    Nov 2011
    friend and friend
    help please ????
  10. #9
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    What part no you have?
  11. The Following User Says Thank You to lupu_sandu For This Useful Post:
    arvedo (2nd September, 2015)
  12. #10
    Nov 2011
    friend and friend
    box is dead after changing km.
    dash not turn this completely off
  13. #11
    What you used for this dash? Digiprog, xtool, xcan or other?
  14. #12
    lupu_sandu's Avatar
    In my immobox...
    Post results
  15. The Following User Says Thank You to lupu_sandu For This Useful Post:
  16. #13
    morocco/fbs
    FOR
    arvedo
    WRITE flash and it will be ok
    chek pass by PM
  17. The Following 4 Users Say Thank You to jokersat For This Useful Post:
    arvedo (2nd September, 2015), koki (25th February, 2018), universalauto05 (29th February, 2016), zi0m3k (16th March, 2016)
  18. #14
    Nov 2011
    friend and friend
    lupu-sandu perfect.
    Thanks everyone for your help
  19. #15
    Feb 2016
    hello someone could give me the pass to download file thanks
