Im assuming you have a fixed dish at 28 east.
So the options are another dish pointing at 13 east or a motorised dish setup
yes you can watch 13 east,you DO need a motorised setup and you can watch most of Europe,there,s not just over priced sly up in the heavens.
slylnb.jpg Or buy this set up for 34quid and line the lnbs up with the sats you wanna hit. Patience is needed for this install if doing yourself.
Smile don?t frown, Look up don?t look down, Believe in yourself, Don?t let yourself go, Just be who you are And let your life flow.
thanks very much every one ...but how will i install the hotbird satellite on my skybox f5 as i am newbie ...thanks it would be great guys...
Mate, get a dual LNB, this will pick up Hotbird and Astra fo you. You wont need another dish.
Cheers
A dual LNB generally means that the LNB has 2 outputs, just like a quad LNB means 4 outputs. It won't allow you to watch 13e & 28e. If you mean a monoblock, I don't think they are available for 15 degrees seperation.
A second LNB on a bracket is only really suitable if you have a dish bigger than a $ly zone 1 mini dish.
If you cannot find a channel list for Hotbird, you can add your own satellite parameters manually.
In the installation menu, select "satellite list". Press green button (Add). Give it a name & enter Longitude (013.0E). The DiSEqC & motor settings depend on how you are going to set up your dish (2 LNB's or motorised).
thanks every one really you guys help me lot thanks..
