Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
  1. #16
    DK Veteran cocoh's Avatar
    Jun 2009
    I think he can't do that..
  2. #17
    impactops's Avatar
    Quote Originally Posted by cocoh View Post
    I think it does not matter how many times you get banned you never learn
    Never assume all the cards are on the table
    Impactops
  3. #18
    hi.
    i need das or xentry SPECIAL OR OFFLINE key for w204.
    WDD6F41W38A149702
    THANKS.
  4. #19
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by giovani View Post
    hi.
    WDD6F41W38A149702
    THANKS.
    Worth a try mate ... 38MKFAMJ3E
  5. The Following 3 Users Say Thank You to PremierD For This Useful Post:
    giovani (4th November, 2013), impactops (5th November, 2013), jimis (7th November, 2013)
  6. #20
    HI.PremierD.
    CODE not work, excuse-me , i put chassis with error, the wrong chassis.!!!!!
    this chassis is correct ( WDDGF41W38A149702 )
    CODE DAS or XENTRY?????
    THANK YOU.
  7. #21
    Feb 2011
    60N 25E
    HI.PremierD.
    THANK YOU.
    Try this offlinecode
    3EMK6U5N7C
    (271113)
    7EM26UDN7C
    (291113)
  8. The Following User Says Thank You to MBFIX For This Useful Post:
    giovani (27th November, 2013)
  9. #22
    North West
    I have tried this software calculator so many times, As far as I am concerned it does not work on anything...... plus some of the menus are not accurate descriptions of the process.
    I tried it with 11.11 12/05 13.03 and it is not worth testing on 09.2013 - maybe I should spend more time translating development Data, there is a lot more in there we do not use or understand...
    If anyone has had any success with this calculator please give details, and if u can take a pictureof it working showing versions, date as, etc/
    ...even better
  10. #23
    Newbie apr73's Avatar
    Nov 2011
    Indiana, USA
    Hello impactops, I have replaced a wsp module but am unable to generate the key FDOK to lernthe transponder. Can You Help With This?
    CHASIS: WD2YD241025355812
    RANDOM NUMBER: 7C F4
    ID CODE (SERIAL NUMBER OF CONTROL MODULE WSP): BA 12 D0 46
    CALCULATION TYPE: X1
    NUMBER OF KEYS: 1
    TRANSPONDER CODE: 8B 8B A5 68 FB
    Thanks for any help and advice you can give me. The way DAS is set up I thought I was able to generate it myself through the learning keys but it was not in the menu.
    Thanks Again!
  11. #24
    Feb 2011
    60N 25E
    Quote Originally Posted by apr73 View Post
    NUMBER OF KEYS: 1
    Thanks Again!
    Random no change evry time when you make new connection wsp
    (you need code seim time when you is it conneted)
  12. #25
    Newbie McTallman's Avatar
    Feb 2014
    Norway
    Keygen for 22 special functions available for free. PM for link.
    Best regards
    McTallman
  13. The Following 21 Users Say Thank You to McTallman For This Useful Post:
    ACDC (6th October, 2014), ahadi (5th May, 2014), andrius (5th October, 2014), bugajewski_pl (4th March, 2014), DB_member (25th February, 2014), eliasole (24th February, 2014), maddy7 (24th February, 2014), MBFIX (6th March, 2014), MishaNew (9th January, 2024), mrouzo (13th April, 2015), nhojyelbom (5th May, 2015), niko75 (19th May, 2014), Novik_UA (8th May, 2014), Pali33 (8th May, 2014), pao (12th September, 2016), said72 (14th April, 2014), schwobaschlamber (13th May, 2014), SergeyIg (11th March, 2014), sherl645 (12th December, 2015), taxo1965 (11th October, 2017), wuerfel (21st November, 2016)
  14. #26
    Jan 2017
    anyone have a password gen for 09/2015 xentry?
  15. #27
    Aug 2015
    Inside A Brain Box
    Thank you, its good to have it.
  16. #28
    fixanycar's Avatar
    here
    NUMBER OF KEYS: 1
    Thanks Again!
    How did you resolve this? I was stuck with the same situation, had to go eeprom.
    Any idea from anyone why FDOK calculation doesn't work?
    Sent from my XT1650 using Tapatalk
  17. #29
    Jul 2019
    Quote Originally Posted by impactops View Post
    All is not lost Gentlemen, Provide Vin & the function you want from the list below & i'll post password on this thread
    EIS EZS
    Air conditioning
    IC belt warningMoTel
    DiS RWTS 211
    TELLE All roaming
    IC reverse gear warning
    IC special settings
    IC search mode unlock
    ABR erase VIN
    ABR VIN manual editing
    ABR Eeprom memory
    SRS deactivate
    SRS Systeminfo
    SRS Training
    SAM R Alarm
    SAM F Trunk illumination
    Centr.Lock/H beams/FoglightsR
    DPF & ECU Flashing
    CDI2 EGR adjustment
    CDI4 EGR adjustment
    ISM Shiftmodule
    Aut.Transm.Correction Programing
    OFFLINE Programming
    FDOK blocked vehicles
    FDOK Unlock Documentation
    Impactops
    Is there a password for special function ABR module?
    Im trying to end the rig test i accidently started
  18. #30
    Top Poster abdulsattar's Avatar
    Nov 2016
    I can help with translating guys, I'm a fluent German speaker
