USB serial RS232 adapter cable installation in Linux Mint
Results 1 to 3 of 3
    Jul 2013
    Default USB serial RS232 adapter cable installation in Linux Mint
    Total Linux Mint beginner here. I got this usb serial adapter cable but I have no idea how to install it in Linux Mint. Can anybody give me an idea where to start?
    GastonJ's Avatar
    I wouldn't normally point someone out to another forum, but you need to read this and check yourself
    Linux Mint Forums ? View topic - [SOLVED] USB to Serial
    HTH
    Oct 2013
    Quote Originally Posted by EugeneA View Post
    Before you plugin the adapter, run
    tail -f /var/log/messages
    and keep an eye on it, as you plug in the USB adapter.
    Now you should be able to figure out what your adapter gets linked to (/dev/something)
    Then plugin the serial cable to the device you are trying to have a link with,
    and then just use screen:
    screen /dev/something
    If you haven't got screen yet, just install it:
    apt-get install screen
    Press enter once or twice and screen will automagically figure out speed and parity.
    Cheers,
    Wim
