Page 4 of 10 FirstFirst 123456789 ... LastLast
Results 46 to 60 of 138
  1. #46
    rob h's Avatar
    May 2011
    Quote Originally Posted by rivalryan View Post
    ID48 are reusable but not all, they have a number of known passwords, this is what the software runs through when trying to unlock used ones, I have quite a high success rate on these. Im not sure if you want to incorporate this type of info though ;-)
    When i have new transponders id48,
    I just write the lines 10 and 11 with 0000 first.
    I use Tango for this and can Always reused these over and over.
  2. The Following 2 Users Say Thank You to rob h For This Useful Post:
    lalaina74 (12th July, 2016), ranchero (29th February, 2020)
  3. #47
    cjawahir's Avatar
    T&T
    Quote Originally Posted by rob h View Post
    U mean change pin to oooo , word 11 and 10 ?
    what vehicle u test on ?
    cj
  4. #48
    rob h's Avatar
    May 2011
  5. The Following User Says Thank You to rob h For This Useful Post:
    cjawahir (27th September, 2015)
  6. #49
    eugen8's Avatar
    need to know if remote on normal key on Honda CR-V 2007-2008 european market is reusable?
  7. #50
    thats what zed-bull software does also
  8. #51
    cjawahir's Avatar
    T&T
    Quote Originally Posted by eugen8 View Post
    yes it is
    cj
  9. The Following User Says Thank You to cjawahir For This Useful Post:
    eugen8 (27th September, 2015)
  10. #52
    Quote Originally Posted by cjawahir View Post
    cj
    This method should work on all vag equiped with id48 without any exception.
  11. #53
    rob h's Avatar
    May 2011
    I have not tested the id48 eeprom, that is inside id48.jpginside remotes.
    Would like to assume that they work the same way.
  12. #54
    I have just read this type of used remote using Tag Key Tool:
    it is showing Page 10 and 11 as 0000 already, so does this mean it can be used again, i.e transponder can be programmed again?
    below is a new id48 pill tp reading:
  13. #55
    It will show always 00 as it is crypto area too(write only, not read possible).
  14. The Following User Says Thank You to autofan1965 For This Useful Post:
    u.s (29th September, 2015)
  15. #56
    ah ok i see, thanks.
    but, if we write Page 10 and 11 with 0000, then we can re-use the this type of transponder (soldered type) ?
  16. #57
    scotland clydebank
    Can citroen c2 2 button keys used be reused thank you yes or no.
  17. #58
    Jul 2014
    Sofia
    Yes but procedure is complicated. Try to search forum for reusing peugeot, citroen, PSA
  18. #59
    kemaster's Avatar
    BG
    Quote Originally Posted by u.s View Post
    Transponder is Locked (LB1=0 LB0=1) so you need to know that PIN to be able to unlock it. After you unlock it(again- you must know the pin) then you can re-write PIN Bytes.
  19. The Following 2 Users Say Thank You to kemaster For This Useful Post:
    just4upal (8th February, 2016), u.s (29th September, 2015)
  20. #60
    Quote Originally Posted by kemaster View Post
    thanks, in that case i'll do as suggested in the other thread and remove this soldered on TP and glue in a new ID48 pill type TP, and then prepare dealer key.
