full read file looks OK...I thought it may be rolling code..but nope..
something got messed up , better to get that BDm read!
hi friends i hope someone can help me !! i have a problem with a bmw 120d 163 HP year 2004 !!
edc16c35
i read the file with my original MPPS full read and partial read !!
than i tryed to write the ecu !! mpps delete the flash and stack !!
after that i have no communication with the ecu !! i flashed the readed file on bench !! and i have again comm over OBD but car dont start !!
did someone know something about that !!
in the next days i will manage to read the full BDM file !!
is it possible that the fault is in the eeprom ??
ecu faults are only 1 ! injector bank 1
i can clear this fault !! and try to start the fault come up again
thank you !!
yeah read eeprom and BDm...and with original Ori read..we ll restore back the file...If it were rolling you would have got immo errors..but instead you get a strange injector error..
most of the first read is emply...only maps tehre. But you did managed to flash the full read back?
Hello i have read the ecu on bench with my Optican !!
Optican tells me it is full file for recorvery !!
maybe you can have a look, i think the immo (eeprom is inside )
normaly with this files it musst be possible to clone this ecu ???
Full read BDM i will make today or tomorrow !
please have a look at the full file !!
flash is OK. waht s CPU.bin? the eeprom?
Did someone know is immo off possible on this bmw edc16c35 ecus ???
only with BDM or without too ??
BR
post here cas & eprom dde. i will help to start the cars.
Hello Folks,
here is the bmw ecu full BDM read !! i need virgin ecu please
i hope someon can do this for sure ! i dont trust volta !!
thanks !!
BR
Did you solve the problem i have same problem
