Results 1 to 15 of 26
    aftermath's Avatar
    Mar 2008
    Default IPbox 9000 Tools
    PC Editor 1.2.46_Beta 12_2
    aftermath's Avatar
    Mar 2008
    Default Flash Tools v 1.0.2 + USB Driver
    Flash Tools v1.0.2
    aftermath's Avatar
    Mar 2008
    Default MBox Control Centre 1.2
    V.I.P. Member sotiris70's Avatar
    Nov 2008
    Default Scripts for Ipbox 9000 HD
    Here are some scripts for TV listings for Ipbox 9000 HD
    In the file there are the following scripts:
    scrplg-Dutch.sh
    scrplg-Ex-Yu.sh
    scrplg-france.sh
    scrplg-French_Movie_Channels.sh
    scrplg-German.sh
    scrplg-Nova.sh
    scrplg-Orbit.sh
    scrplg-Other_Channels.sh
    scrplg-Portugal.sh
    scrplg-PPV_Movies.sh
    scrplg-Premiere.sh
    scrplg-Scandinavia.sh
    scrplg-Sky_Cinema.sh
    scrplg-Sky_It.sh
    scrplg-Sky_Movies_UK.sh
    scrplg-Sky_Uk.sh
    scrplg-Spain.sh
    scrplg-Tv1000.sh
    Put the files with a ftp programme to var/bin, attibutes 755.
    Many thanks to Rocknroll for the source for these TV listings.
    Enjoy it
    Nov 2008
    IPBOX9000HD_backup
    Makes a copy on the HDD
    Installation:
    - *. Sh and *. txt, copy them to / var / bin
    - chmod 755 to scrplg-backup.sh
    - create a backup subdirectory in the /media with the name <<backup>>
    Run from Sript-Plugin the scrplg-backup.sh
    The file *.tar.gz that will be created (backup) will be found at previously created directory / media / backup.
    To install the *.tar.gz to our receiver, we rename the *.tar.gz to addons.tar.gz and we run it from webinterface (for Sif-team images from Commands --> install addons.tar.gz)
    Thanks to reaper7 for the backup script
    Tested it and works ok
    aftermath's Avatar
    Mar 2008
    Default Tools for IPbox 9000
    pspas 4.5.3.
    This is a very handy tool when text editing files, needed when you flash the Enigma2 image, a plain text editor like notepad wont work for certain files.
    V.I.P. Member satman's Avatar
    Jun 2008
    Never Never Land
    Some ipk addons for
    -Abcom image
    -Cli image
    FTP to /tmp,, goto web interface, Addons>manual>install,, simple as that
    i- Kneubi Bit Rate plugin
    ii- Kneubi Script Run plugin
    iii- Neumoteam games addon - tetris, pong, suduko
    iv- pluginsgames addon - Adds all of above + Kneubi Mail Plugin
    boom!
    aftermath's Avatar
    Mar 2008
    Default USB U-Boot 1.3.3
    For IP box 9000
    For IPbox 900
    aftermath's Avatar
    Mar 2008
    Default IPbox skins
    These skins work on the Enigma2 image on the IPbox 9000.
    Rihanna skins.
    Just unzip to PC and ftp to the same places as in the zipped file on IPbox, once done CHMOD them to 755.
    Nov 2008
    Default WebEPG by Dexter
    WebEPG 0.61
    New option added, with extra plugin which only will run and import epg data and exit.
    For those that wants to automate the process.
    Nov 2008
    Default FPS - Fast Plug-in Starter
    RELEASE 0.1.1
    - added new configuration value 'debug.level'. See DEBUGING & REPORTING
    - plugin now opens TIMEOUT as fast as possible. The gap betwen button to start fps and to choose option
    is no minimal. Still small gap is needed as DGS sbox needs time to run fps
    - plugin stops waiting TIMEOUT when any button press is received.
    Nov 2008
    RELEASE 0.1.2
    - fix of small bug which cause list not to be free. Might help in some rare cases.
    - added one second sleep at the end of plugin to prevent keys been send to DGS
    - fixed wait for key event during TIMEOUT time. TIMEOUT is calculated more preciously
    - plugin sets default colors if it cannot read it from current skin, it happens on sifteam image
    - new configuration options to set colors
    general.background.color=0x0d0e0f
    general.normal.color=0xffffff
    general.focus.color=0x000000
    Thanks to coOLOser
  13. #13
    Nov 2008
    Default PCEditor (Latest):
    PCEditor 1.2.46 Beta13
    - New: Comparing database revisions while uploading channel database
    - New: Messagebox, when database revision of image and uploaded database do not match
    - New: Reorder Favourite Groups to have the same order in the image as in PCEditor. You find this option in the context menu of Favourite Groups.
    - Fixed: Sorting favourite groups didn't work sometimes or showed weird sort orders
    - Fixed: Sometimes uploading the channel database didn't work.
  14. #14
    aftermath's Avatar
    Mar 2008
    Default PC Editor 1.2.48
    PCEditor 1.2.48, 30.01.2009
    - New: Import transponders from satellites.xml generator
    - New: Choose receiver when downloading a channel database
    - New: Added columns transmission and modulation for transponders in NIT Edit
    - New: Auto adjustment of columns in NIT Edit
    - Fixed: Possible problem flashing images via ftp for all receivers
    - Fixed: Wrong context menu in NIT Edit
    - Fixed: Calculating wrong frequency for HD receivers when importing from Dreambox
    - Fixed: Problem detecting DVB-S2 transponders when importing from Dreambox
    - Fixed: Wrong label in general options for "Search by substring"
    - Fixed: Missing scroll bar for channels in NIT Edit
    Download here
    http://www.digital-kaos.co.uk/forums/downloads/pc/9/pc-editor-v-1-2-48-583/
  15. #15
    aftermath's Avatar
    Mar 2008
    Default Goal Alert 0.2.0 Plugin
    goalAlert is a plugin that shows a banner when a goal in Italian serie A,
    serie B, Champions League and Uefa Cup match is scored.
    I am trying to get help making it work for the English Premier League.
    INSTALLATION:
    copy the file: -goalAlert.plugin
    on the path /var/plug-in of your STB
    copy the folder: -goalAlert
    on the path /var of your STB.
    thx ataru_moroboshi80
