Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 53
  1. #31
    Member grizzlyt's Avatar
    Oct 2008
    Default Cube revo single and twin tuner images
    NLB firmware release-9341
    NLB9341 for all IPBOXes
    Image release: NLB-9341-v1.320
    WEBIF
    login: root
    password:relook
    Prepared by : Dexter
    Release date : May 3. 2009
    Changes:
    * updated - Based on DGStation SVN9341
    * emu - updated - Hypercam 1.03
    * emu - updated - IncubugCamd 0.82
    * emu - updated - mbox 0.5 Build 08
    * carddriver- updated pacco carddriver 090502.
    * skins - deepblue, grey and blue updated to r9341.
    * plugins - updated - favpip v2.1.1
    * plugins - updated - bitrate 0.0.6
    * plugins - fancontrol 0.1 (change config to /var/etc/fancontrol.config to activate)
    * newcs - removed cardlevel from all config files. (seems to cause problems)
    IP 91/DGS 250 HD
    RapidShare: Easy Filehosting
    IP900 HD
    IP 910 HD
    IP 9000 HD
    DGS 200 HD
    IP Box HD 9000 2xS2 tuner
    Dreambox 7025-SS
    Smart MX 28-IDTE IQ 2040
    Sammy 9500-Sammy 9400-Sammy 9000
    Triax 120 cm-Titanium 2 LNB's
  2. #32
    aftermath's Avatar
    Mar 2008
    Default NLB9580_9000HD at last released
    nlb9580_9000HD_release
    DGStation/Abcom CubeRevo Series nlb svn9580
    Unofficial Custom release - no limits board
    WEB-IF
    login: root
    password: relook
    Image release: NLB-9580
    Prepared by : Rainman
    Release date : June 18. 2009
    Changes:
    * updated - Based on DGStation SVN9580
    * emu - updated - IncubusCamd 0.85
    * emu - updated - mbox 0.6 Build 0006
    * skins - only original skin, other skins removed ...only "cool"-skin working !
    * satangels keyupdater included
    Thanx to my friend Dexter for getting me started in building images !
    Thanx also for all the beta-testers, especially to Minicat for testing my very first beta
  3. #33
    aftermath's Avatar
    Mar 2008
    Default DGS r10336 For Ipbox 9000
    New release of DGS is out :
    From readme file :
    1. Add iCubeRevo function
    : If you have the iPhone(or iPod), you can operate the STB via iPhone(or iPod).
    More description is attached. The file name is "iCubeRevo_manual.pdf".
    2. Add streaming player function
    : Bi-directional stream transmission between STB and PC is possible.
    Several protocols(UDP, RTP) are supported. And Multicast or unicast are supported.
    More description is attached. The file name is "MultiRoom and Streaming manual.pdf".
    3. Add multiroom service function
    : Several STBs can access the Server STB and see the Server's file, mp3, video player and channels.
    4. Add M3U Player function
    : M3U is a format that stores multimedia playlists.
    Our M3U player can play XVID(Without GMC and Qpel), MPEG1, MPEG2, H.264.
    5. Improv Nordic subtitle (Canal Film HD, Silver HD, BBC HD and so on)
    : For the meantime, we didn't display subtitle without PTS or with wrong PTS.
    But, at present, we support these subtitle.
    6. Improve the channel navigation
    : You can see the faster movement at the channel, Fav, epg list and so on.
    7. Fixed incorrect aspect ratio for 4:3 channels
    : For the meantime, our STB displayed PillarBox, Zoom with a little distortion.
    8. Fixed subtitle overlaping on Hotbird.
    : Hotbird 13E 11766 V 27500 (channel name : Rai1, Rai2, Rai3)
    9. Fixed ttxt subtitle page at the specific pages(775~777)
    : Hotbird 13E 11919 V 27500 (channel name : Italia 1, Canale 5, Retequattro)
    10. Update russian language file by uncle fedor.
    11. Update german language file by Nils.
    Note.
    1. When multiroom service and streaming player is running, recording and pip doesn't support.
    2. Our Video player is related with CODEC, FPS(frame per second) and resolution.
    As you know, even if the Filename Extension is different each other,
    if the video codec is same each other, the two files work like same.
    If the video file's resolution is more than 720 X 576, it will works very well.
    So, we recommend below conditions.
    1) resolution : 720 X 576.
    2) FPS : 24, 25 and 30 fps.
    3) Following video and audio codec.
    Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
    Audio Codec : MP2, MP3, AC3
    When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
    If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
    3. ext3 file system is slower than ext2 normally.
    If you record two HD channels with ext3 at the same time, it may fail in record.
    we have checked the speed as below
    ext2 speed : approximately 7MB/s
    ext3 speed : approximately 3MB/s
    Known issues(on going).
    1. Artefact with Premiere HD channels from satellite or cable.
    2. The timeshift function of multiroom will release on the next.
    Caution.
    1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
    2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one.
  4. #34
    aftermath's Avatar
    Mar 2008
    Default Sifteam r10336 for IPbox9000HD
    Based on DGS version 10336
    Today new release of DGS is out :
    From readme file :
    Note.
    Caution.
    get it here
  5. #35
    aftermath's Avatar
    Mar 2008
    Default Sifteam 0.3.0 release version 10513 for IPbox9000HD
    SifTeam 0.3.0 r10513 for Ipbox 9000HD
    Changelog DGS:
    DGS release r10513: ( 21/Aug/2009)
    1. Fixed a few bugs for Post-Descramble
    2. Return to previous method that select subtitle language in Language settings Menu
    3. Fixed some bugs for Multiroom Service.
    Protocol for mutiroom service is changed from this version. So, older SW(r10427) is not compatible with this SW(r10513).
    Changelog SifTeam:
    SifTeam-0.3.0
    From this release I add DGS Multiboot options *
    From default start without check or format HardDisk (requested) **
    Is possible don't start any Service at startup ***
    Personalized SAMBA and NFSD config ****
    Any change in panel
    * Press number button which you want on RCU when start decoder.
    Multiboot function supports as below style.
    # 1 boot with CDKroot(NFS)
    # 2 boot from USB memory stick, with internal HDD
    # 3 original images as current flash memory
    # 4 boot with NFS
    # 5 boot from USB memory stick, but without internal HDD
    # 6 boot from internal SATA HDD
    # 7 boot from flash memory for another image
    Default value : no.3
    ** Remove file:
    /var/etc/.dont_format_hdd
    /var/etc/.dont_check_hdd
    ..and return as default system
    *** Make file:
    /var/etc/.dont_start_samba If present, at startup don't start samba
    /var/etc/.dont_start_nfsd If present, at startup don't start nfsd
    /var/etc/.dont_start_httpd If present, at startup don't start httpd
    /var/etc/.dont_mount_usb If present, at startup don't mount usb
    /var/etc/.dont_start_vsftpd If present, at startup don't start vsftpd
    **** Make directory:
    /media/ENIGMA1/movie
    From other decoder with enigma1 firmware (for example SifTeam Firmware)
    Add this command for share disk with samba:
    smbmount "//192.168.1.9/ENIGMA1" -U root -c 'mount /hdd/ -u 500 -g 100'
    Add this command for share disk with nfs:
    mount -t nfs -o nolock,nfsvers=2,rsize=8192,wsize=8192,proto=tcp 192.168.1.9:/media/ENIGMA1 /hdd
    192.168.1.9 is IP of IPBOXHD shared disk, ..change with your IP!!
    In all Sifteam Firmware is possible add this command at bottom of file /var/etc/rcS.d/S99user_start.sh
    and automount at startup.
    UNZIP AND RENAME FILE TO usb_update.img
  6. #36
    aftermath's Avatar
    Mar 2008
    Default NLB-10513-v1.50 for Ipbox 9000
    DGStation CubeRevo Series nlb svn10513 v1.5
    WEBIF
    login: root
    password: relook
    Image release: NLB-10513-v1.50
    ***** SPECIAL ONE-TIME RELEASE *****
    No big developer add-ons, no full doc updates, just plain binary/emu update.
    Release date : Aug 21. 2009
    Changes:
    * updated - Based on DGStation SVN10513
    * emu - updated - possible mgcamd 1.33 (soon!)
    * emu - updated - IncubusCamd 0.92
    * emu - updated - mg_launcher 0.3
    * other - updated - streamtools
    * webif - updated - dgs webif 1.38
    * skins - removed old grey blue skins
    * plugins - updated - favpip v2.1.3
  7. #37
    aftermath's Avatar
    Mar 2008
    Default DGS release r11102: ( 18/Oct/2009)
    1. Improved sync of dvb-subtitle .
    - if correct PTS from the stream, no problem
    But if wrong or missing PTS data from the stream, it possible to time difference with A/V and subtitle.
    2. Changed concept for Streaming Player function
    - watching one channel, another channel streaming independantly
    3. Added unicable function on LNB type of satellite configuration menu as C, Ku, UNIV, Unicable
    - Caution : At this moment ,you have to install unicable for each of tuner because it is not supported both tuner 1,2 in one menu at the same time
    4. Improved visibility of menu font
    5. Small many bugs fixed
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
  8. #38
    aftermath's Avatar
    Mar 2008
    Default SifTeam 0.3.0 r11102 For Ipbox 9000
    DGS release r11102:
    - Caution: At this moment ,you have to install unicable for each of tuner
    5. Many small bugs fixed
  9. #39
    aftermath's Avatar
    Mar 2008
    Default NLB11102 for IPbox 9000HD
    nlb11102 for IPBox 9000HD
    Image release: NLB-11102-v1.51 no limits board
    visit us on nlb.to
    Prepared by : no limits board
    Release date : Oct 21, 2009
    Changes:
    * updated - Based on DGStation SVN11102
    * emu - IncubusCamd 0.93
    * emu - mbox 0.4 build 0023 (gbox support)
    * emu - mgcamd 1.33 (starts by default)
    * webif - updated - dgs webif 1.4.03
    * plugins - updated - favpip v2.3.0
    * keyupdater included
    * nlbpanel included
    * and some other plugins :-)
    * info: only cool-skin installed ... deep-blue follows l8r
    to use old database on this image
    upload to the very latest PC editor,here , then save back to PC
    FTP db.dat to the /var folder on IPbox
    rename it to db.dat.edited
    switch off the box , then back on
    this way you will get you database running on this image
    Download from here RapidShare: 1-CLICK Web hosting - Easy Filehosting
  10. #40
    Oct 2008
    Thumbs up NLB11102 9000 DHCP bugfix
    Oct 22, 2009:
    Bugfix release: Image will also boot if no LAN w/ DHCP is connected (tested)
    Image release: NLB-11102-v1.51 No Limits Board
    visit us on Startseite - no limits board
    Changes:
    ? updated - Based on DGStation SVN11102
    ? emu - IncubusCamd 0.93
    ? emu - mbox 0.4 build 0023 (gbox support)
    ? emu - mgcamd 1.33 (starts by default)
    ? other - updated - streamtools
    ? webif - updated - dgs webif 1.4.03
    ? plugins - updated - favpip v2.3.0
    ? keyupdater included
    ? nlbpanel included
    ? and some other plugins :-)
    ? info: only cool-skin installed
    NLB11102 9000 fix DHCP
    Dreambox 7025-SS
  11. #41
    Oct 2008
    Default PKT mod 6.01 Tideglo rev 0.6.0-flash versions
    Release date : Nov 21, 2009
    Changes:
    ? a new default look: BlackGlass HD skin, thanks to Father Pio
    ? new Media center, thanks Father Pio
    ? new list of channels from 02.11.2009 by djcrash
    ? new mount manager 0.7.0
    ? spinner selector thanks to j00zek
    ? multilingual
    ? fixes for the second tuner - no longer restarts in a loop
    ? minor corrections with the Sharp tuner
    Regards Polish Team Kathi
    Flash Versions:
    PKT mod 6.01-flash-version 9000 HD
    PKT mod 6.01-flash-version 910 HD
    PKT mod 6.01-flash-version 900 HD
    There is currently no 91HD version...
    Dreambox 7025-SS
  12. #42
    aftermath's Avatar
    Mar 2008
    As post above but a few fixes and updated
    Release date : Nov 22, 2009
    Changes:
    ? multilingual
    Flash Versions:
    900 version for flash
    9000 version for flash
    910 version for flash
  13. #43
    Sep 2008
    as there is no n3 fix for irl is it just for sat side or will it it also change the dvb/c side aswell asit is a long time since i have seen that box .thanks
  14. #44
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by cactikid View Post
    mainly for sat side i would say, but this box is capable of handling IPTV so time will tell i suppose.
    everything takes time but who knows what is around the corner
  15. #45
    aftermath's Avatar
    Mar 2008
    Default PKT mod 6.01c Tideglo rev 0.6.0 Flash Version
    24.11.2009
    PKT mod 6.01c Tideglo rev 0.6.0 for Ibox 9000HD, 900HD, 910HD Flash Version
    Flash Version
    What's new:
    - A new default look BlackGlass HD thanks Father Pio
    - New Media Center, thanks Father Pio
    - Channel list 22.11.2009 by Catseye
    - New MountManager 0.7.0
    - Thanks to Spinner Selector j00zek
    - Multilingualism
    - Patch for the second head - he did not restart the loop
    - Minor corrections to the heads Sharp
    9000 version
    900 version
    910 version
