Results 1 to 13 of 13
    DK Veteran ivica's Avatar
    Apr 2009
    Default pasaat edc15 hot start fix help
    Please can you help with hot start problem
    38906019EP
    1,9l R4 EDC
    WVWZZZ3BZ2E217209
    1037362702
    0281010701
    Flash:29F400BT
    file is at attachment
    FAP Remover
    bmw320d's Avatar
    Hi your hot fix
    hi
    try this file
    regards
    Jun 2013
    I mean that was mehanic problem, for edc15 take your vcds and look at mean blocks for ignition!
    Nov 2011
    friend and friend
    Friend Auto ecu this is done, the hot start and it works beautifully, better than new
    Nov 2017
    Have you picture for EDC15 hotstart map in 2d for winols?
    And comparation with fix map.
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  8. The Following User Says Thank You to Ignasvw For This Useful Post:
    mexanico1971 (18th October, 2019)
    Apr 2016
    Default passat edc15 hot start fix
    hello. I have hot start problem passat edc15 . can somebody help me? thanks
  10. #9
    This is hot start fixed.
  11. The Following 2 Users Say Thank You to nikka For This Useful Post:
    mandras (28th July, 2020), szucsyy (22nd September, 2018)
  12. #10
    Pleas hot start fix for skoda edc15
  13. #11
    dominik.m's Avatar
    Jun 2009
    POLAND
    Quote Originally Posted by ROMIKUS View Post
    Read again. Your file should have 512kb, not 207kb.
  14. #12
    Here ist OK BIN
  15. #13
    Mar 2018
    Serbia
    Here is ur file
