Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Softcams
Hybrid View
    P&D's Avatar
    May 2010
    Default Softcams
    Is it possible to put a softcam on a VU+ solo 2 ??
    Latest Vix image
    Many thx
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    they can be added on all images
    via the tmp folder then you load
    them from the manual package install
    section in the box menu, here are the cam
    packs for you
    http://www.4shared.com/dir/wnyHV50A/VIX_CAMS.html
    Last edited by digicon; 1st October, 2013 at 11:28 PM. Reason: Removed Cam Pack and replaced with External link
    Please Read Carefully!
    digicon's Avatar
    Jul 2009
    Hi Benny,
    Sorry my good man but we cant hold any form of cams on the site including built into images due to the rules, We can though link to them externally from other hosting sites without a problem so i have edited your post to reflect this.
    Thank you
    P&D's Avatar
    May 2010
    Hi many thx benny/9 for the reply....
    Sorry my 1st post is misleading (sorry about this) i already have some of them installed on the VU....ccam 2.4.1 & mgccam also oscam
    the box is running great many thx for the help off other members of the forum...
    I mean the k**s like the ones in the Latest Technomate Softcam Keys *Regularly Updated*
    or similar to work with the VU
    Not sure if this is possible (i could do it on the F3 box i had) but is it possible on this box.....
    or am i barking you the wrong tree ???
    Only had the box under a week....as digicon assured me that the setup it easy (which it was) & a lot of reading helped thx again for the pointers mate
    Had a play with the B/H latest image...it's ok... but now i find the openvix is more user friendly & easier to get your head round...
    I have found out how to load stuff on the box via ftp & ipk & usb....editing files that i need to....
    After all the the above said.......i have the files for the F3 box that opened some sat's that i could watch. lets say 39.2E ...N**a S***t... is it possible to put the same file's on the VU
    attached below...
    Or again am i barking up the wrong tree...to get what i want
    Just cannot get my head around where to put them ...&..which flies go where .....iv'e try'd them in Var/keys..also Usr/keys
    Any pointer's plz anyone thx in advance...
    digicon's Avatar
    Jul 2009
    Ok
    Here we go not tested by myself but here is the latest Dreambox softcam.key file which goes into /usr/keys:
    Update: Bulsat 39.0?E Irdeto Active and Next key's
    Cablecom, Swiss Cable
    SRTV Feed 16?E BISS
    NBA Pool Europe 10?E BISS
    Rai october 13.0?E
    Rai 13.0?E September
    NBA TV HD 10.0?E BISS
    Barca tv (feed) 10.0?E BISS
    MUTV 10.0?E Biss
    USRSC Europe ESPN 10?E BISS
    ETV 3.1?E BISS
    EVN TV BISS 7?E
    Sinema TV Aksiyon HD & Sinema Ask TV HD 4.9?E BISS
    NLO TV 4.8?E BISS
    Pershy Natsionaly 4.0?W BISS
    REN TV 49.0?E BISS
    Art Prime Sport 49?E BISS
    BBC Package 27.5?W BISS
    Fox Crime Africa SD 12.5W BISS
    ESPN Caribbean & ESPN Syndication 15?W BISS
    Eurofootball Gonki 9.0?E BISS
    TNTsat Viaccess 19.2?E
    CS SkyLink 23.5?E CryptoWorks
    DigiTurk 7?E CryptoWorks
    Upc Direct 0.8?W CryptoWorks
    ORF & AustriaSat 19.2?E CryptoWorks
    UPC Cablecom (Swiss cable network) NagraVision
    Thanks to Serjoga for all the hard work, just to let you know you will need 2 cam emulator's for this key file to work one begins with C and the other begins with M and ends 1.38.
    Just to let you know why you need the 2 some are read by one emulator and some by the other.
  6. The Following User Says Thank You to digicon For This Useful Post:
    P&D (2nd October, 2013)
  7. #6
    P&D's Avatar
    May 2010
    Hi digicon many thx for the answer
    i will try them later when i finish at work.....
    When you say i need the 2 files ...i now have them....do you just swap & activate them from the menu...i know they will not both run at the same time...
    what i'm asking is one file will work with some sat's (lets say the M file) .....if the sat does not clear then swap to the other file (C) ??
    Sorry to be a pain mate...so the dreambox k**s are ok for the E2 systems....
    Regards P&D
  8. #7
    digicon's Avatar
    Jul 2009
    Dreambox are Enigma2 so yes they work on any E2 Linux receiver.
    And again correct for some channels that wont open on one cam with the keys you swap to the other cam, as you are now using the Vix image i am unfamiliar if it has an Autocam function built in.
    Blackhole does have Autocam function built in so when you get channels open with say Cam A you save these to open with A and the rest you save with Cam B. So when you go to that said channel it opens with either A or B automatically.
    Like i said i have no idea if the Vix image has this function so you may have to have a look around the menu system
  9. The Following User Says Thank You to digicon For This Useful Post:
  10. #8
    P&D's Avatar
    May 2010
    Hi digicon many thx for the pointers
    I have re-installed B/H 2.0.6 with both the files you have mentioned above...all working great mate only had time to check 39E & N*** S***** opens
    so i will check he others later also thx for the pointers with the autocam....great little thing save swapping it everytime you change the sat ...
    My next challenge is find sats i can open......1. last question mate should the sats above that have the Bliss keys open with the same file ???
    Regards P&D
  11. #9
    digicon's Avatar
    Jul 2009
    They should yes again though it will depend if the key in the file is current or not even though they list them up to date even the softcam makers have been known to leave old and dead keys in the file, try a few and see how you go as some may have a clash with others due to format
  12. The Following User Says Thank You to digicon For This Useful Post:
    P&D (3rd October, 2013)
  13. #10
    P&D's Avatar
    May 2010
    Many thx for all your help digicon....
    You are defo on my Christmas card list
    Only for your advice i wouldn't of took the next step into the wounderful world of the Sat's
    As you said to me in one of your post's it's not the daunting to setup & take the next setp (glad i listened to you).....
    My advice to anyone & all
    If your thing of upgrading from the CHEAP boxes go for it....motor dish setup 3 days (Don't laugh) 1st attempted
    Box setup 3 days after trying the Vix image & the B/hole image (& many pointers from forum members) Many thx to all.....
    I now can pass on what i have learnt this week to other members starting out....
    Again many thx Phil
  14. #11
    Jan 2014
    Thought i'd bring this thread back rather than starting a new one. Not sure where to put the key files on my VU+Duo2. Any pointers? cheers.
  15. #12
    V.I.P. Member mdt's Avatar
    Feb 2009
    bolton, north-west. uk
    Quote Originally Posted by DigitalVandal View Post
    USR/KEYS,regards mdt
  16. The Following User Says Thank You to mdt For This Useful Post:
    DigitalVandal (23rd March, 2014)
  17. #13
    Jan 2014
    top man. thanks for almost immediate answer.
  18. #14
    digicon's Avatar
    Jul 2009
    And while we are on it might as well try and keep them up to date:
    Thanks to Serjoga for the key File
    ADD: ESP2 NE Russian 13.0?E 11240 V 27500 CCW's
    NTV Mir 4.0?W BISS
    Juventus TV Channel ("ITA 392") 5?W BISS
    BBC Package 27.5?W BISS DOWN
    NLO TV 4.9?E BISS
    Chveni Magti, Magti Kino, Comedy Arkhi, Magti Hiti HD 4.9?E BISS
    Italy Service & Italy Service 2 & Italy Service 3 & Italiy Service 4 9?E BISS
    FOX Sports 9?E BISS
    BARCA FeeD 10.0?E BISS
    NBA Pool Europe 10?E BISS DOWN
    STS International 13.0?E BISS
    K**** D1 16.0?E BISS
    SRTV Feed 16?E BISS
    Topaz 1 21.5E BISS
    CaspioNet and CaspioNet_test 31.5?E BISS
    BTB 31.5?E BISS
    Comedy Central 31.5?E BISS
    Region TV 46?E BISS
    CTC Love 85.1?E BISS
    Mir Belogorje 85.1?E BISS "radio"
    TNT Sat (France) HD 19.2E Viaccess Only with o****-ymodv18-t50
    TNT Sat (France) SD 19.2E Viaccess Only with o****-ymodv18-t50
    Ant-1 Europe 9?E Viaccess
    GMM Package 78.5?E Irdeto
  19. The Following User Says Thank You to digicon For This Useful Post:
    DigitalVandal (24th March, 2014)
  20. #15
    Jan 2014
    Do they work with 1.35 as they're not opening for me.
