Results 1 to 14 of 14
    Newbie MENTE SICULA's Avatar
    Sep 2013
    Default Vu+ Solo : BlackHole 2.0.6 Ferrari V2/V3 by Toysoft
    Toysoft
    great member of *******just have patch last Black Hole image for Vu+ Solo Ferrari clone
    Black Hole 2.0.6
    What is new ?
    * New Plugin Net Drive
    * New Coherence UPnP Renderer
    * New Coherence UPnP Server
    * Removed Dlna Djmount client Bh version
    * Removed Minidlna Bh version
    * Added Vu+ Dlna Browser (based on djmount)
    * Added Vu+ Minidlna server
    * Fix and Update MyTube plugin
    * Update lcd4linux
    * Update Openwebif
    * Update all dtt drivers
    * Update TranscodingSetup plugin
    Vu+ Drivers:
    * 20130918
    - Fix transcoding problem(duo2)
    * - Fix vtuner problem(duo2, solo2)
    * - Support non bcma encrypted PCMWAV in media playback
    - Add missing entries in framerate_choices(duo2, solo2)
    - Support 4 vtuners(duo2, solo2)
    - Support transcoding in vtuner(duo2, solo2)
    * Fix 1080i problem (duo2)
    * Fix AC3 sound problem (duo2)
    * - Fix DTSHD downmix & passthrough
    - Support more than 4 tuners(vtuner) in duo2 and ultimo
    - Fix play/pause in solo2(when duo2's new remote control is used)
    - Fix Xcrypt card detection problem(duo2, solo2, uno, ultimo)
    - Support transcoding bitrate/framerate setup
    (solo2, 50K<bitrate<1M, Change is in effect in the subsequent connection )
    Misc:
    * [dvbmediasink] support DDP patch.
    * Add curlftpfs
    * [wlan] added driver for Realtek 8188EU chipset
    * [mt7610u] Added D-Link DWA-171 Rev. B1
    * [wlan] Added new Realtek Driver - 8812A - 8821A who support AC standard
    * Update HbbTv
    * Add python packages: misc, shell, types
    * Update af9035 firmware.
    * Increase vtuner number in udev up to 4
    * TransCodingSetup : set defalut bitrate of SOLO2
    * TranscodingSetup : change bitrate range (solo2, 50k ~ 1M)
    * TranscodingSetup : add framerate settings (25k, 50k)
    * TranscodingSetup : add default button
    * TranscodingSetup : use notifiers for set change
    * AudioSelection : Dolby Digital downmix -> Dolby Digital / DTS downmix
    * ServiceInfo : crash fix.
    * Update languges Cs, Da, No, Ru, Sk, Sv
    Howto Dlna Renderer:
    Enable UpNP renderer in Black Hole Speed Up
    Start Bubbleupnp, Devices, Renderers and choose duo2, solo2, solo or the box name available.
    Then choose library choose a media and press play.
    You will play your media to your box.
    You can use native Samsung Galaxy player (video, gallery, media) by pressing *))) ] (allshare)
    WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.
    The image MUST be installed in flash.
    Black Hole does not support images not installed in flash.
    This latest version of the Black Hole series has been entirely rewritten and improved in the code for maximum stability and performance.
    Please note that of all images Black Hole now has the best epg system:
    - Integrated OpenEpg
    - Rytec dedicated epg.dat
    - New system epg.dat outside.
    This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
    Community members can then download it from our servers.
    This feature provides other benefits such as:
    Increase download speed of EPG
    Download EPG from any channel
    Schedule the download of EPG decoder even during standby
    Users can customize the providers using Add / Remove function
    Main functions of the buttons on the remote
    OK button = Skin with simple information
    OK button x 2 = Extra Info Skin
    Blue button = Black Hole Blue Panel
    Blue button and then Red button = Black Hole Epg Panel
    Blue button and then Yellow button = System Monitor Panel
    Blue button long press = Extensions
    Yellow button = Audio menu
    Green button = Black Hole Green Panel
    Green button long press = Subservices
    Green button and then Red button = Fast Plugin Setup
    Green button x 2 = Fast Plugin
    Button Red short press= access HbbTv functions
    Button Red long press= Red Panel (Parallel Universes Teleportation)
    Addons
    Green button and then Yellow button takes you to:-
    Dedicated server for BlackHole addons
    Download and install additional packages from the Black Hole server
    Infobar / OSD
    ****og Clock Gui
    Channel orbital location
    Advanced Tuner Info: Sr Freq Pol Fec
    Signal SNR, BER
    Infobar picons
    Characteristics of BlackHole Panels
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Black Hole Cron Manager (Manage schedules)
    OSD Settings (OSD configuration)
    Devices Manager
    Usb Format Wizard
    Kernel Modules Manager(Kernel module operator)
    Inadyn Settings (Configure Inadyn)
    Swap File Settings (Configure File Swap)
    Hard Disk Settings (Configure Hard Drive)
    OpenVPN Panel ( OpenVPN Panel)
    Samba / CIFS Panel ( Samba Panel)
    NFS Server Panel ( NFS server Panel)
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UPnP Server Mediatomb
    UpnP Server Minidlna
    Pcsc Panel
    Tuner Server
    Network Browse & Mountpoints
    Info Panel
    1 - Gui Setting (Gui configurations)
    2 - Service Information (information system)
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Global settings (global settings EPG)
    Setting Provider (ISP settings)
    Green Panel
    Fast Plugin Setup (Configure quick access to your favourite plugin)
    Fast Plugin (Access your favourite plugin)
    Addons (added)
    Addons Download Manager (Manager for package downloading)
    Online Feeds Settings update
    Online Black Hole image update
    Manual Install BH packges (Manual installation of Black Hole packages)
    Manual Install IPK packages (Manual installation of IPK packages)
    Addons Uninstall Panel (Uninstalled packages)
    Black Hole Statistics (See connections, top downloads and more)
    Red Panel
    BH Parallel Universe Teleportation
    Black Hole
    Avalon
    Chaos
    Ghost
    Credits
    Thanks to Pedro_Newbie for Backup script
    Thanks to the group of Beta Testers.
    Thanks to Rytec for providing us with the server with all epg.dat files.
    Thanks to MaxZ4 for Integrated EPG loader.
    Thanks to Skaman for Cross EPG
    Thanks to Lukkino (VDR-Italy) for the source code of OpenTV.
    Thanks to Reinh@rd for the file satellites.xml.
    Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
    DISCLAIMER
    THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
    THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
    LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
    LICENSE (TERM OF USE)
    THE BLACK HOLE IMAGE IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY AND THAT IT WILL ONLY BE USED FOR LAWFUL PURPOSES.
    ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REVOKE OF THIS LICENSE.
    This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.
    DOWNLOAD:
    BlackHole 2.0.6 Ferrari V3
    Last edited by MENTE SICULA; 5th October, 2013 at 03:30 PM. Reason: Do not post other forum references
  2. The Following 8 Users Say Thank You to MENTE SICULA For This Useful Post:
    acres09 (11th May, 2015), beeb2412 (3rd January, 2014), choca (8th December, 2013), kleeerbox (25th January, 2018), morto (17th November, 2013), notluckyuk (25th January, 2014), toysoft (30th October, 2013)
  3. #2
    May 2008
    will this work with a clonebox icloud (openbox6000hd)
    digicon's Avatar
    Jul 2009
    Quote Originally Posted by wakkaday View Post
    The Title header says Vu Solo and as the 6000HD is a Solo clone it should work no problem
    Dec 2010
    I cant find the user name and password any where??
    can some kind soul help me as im itching to set it up and cant seem to find this small piece of vital info!
  6. #5
    P&D's Avatar
    May 2010
    Quote Originally Posted by Pillhead View Post
    Hi if you mean for you box using VUCC or DCC ???
    default is set
    User=root
    pass= left blank
    Unless you have already set a user & pass
  7. #6
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    the default is set User---root and password----dreambox
    on every new version of the DCC i have downloaded
    if you want the latest DCC e2 150 version you can
    download free from here BernyR's Dreambox Tools
    Please Read Carefully!
  8. #7
    Dec 2010
    sorry guys my fault i was trying to connect to thr wrong ip addy
  9. #8
    Feb 2014
    Hi in using the same black hole image BlackHole 2.0.6 Ferrari V3. I also installed TSmedia 7.3 but te channels are not working, do I have to do something in order to make them work.
  10. #9
    Top Poster Swiftie's Avatar
    Jul 2009
    Trying to help someone who borked his clone box with an official release. He thought it was a genuine box until when I found this image to disprove his seller.
    His box, boots up but no TV signal.
    Can I just instruct him to download this to his USB, reboot and it would just flash as per normal or are there special instructions required?
    E Pluribus Unum
    From the one to whom much has been entrusted, even more will be demanded!
    If you have received help from this post, press the "THANKS" button to show your appreciation.
  11. The Following User Says Thank You to Swiftie For This Useful Post:
    2bagstew (13th November, 2015)
  12. #10
    Mar 2011
    try and flash with a clone release if that doesn't work connect to your pc with the adapter thats supplied with most clones and flash from
    VU+ Images
  13. #11
    Jul 2009
    Managed to guide him on how to use USB again (even though its not a hard task) to flash BlackHole 2.1.0.1 Ferrari V3 and he's reporting that he's back in business.
    Now the fun part of helping him with the rest of the config.
    E Pluribus Unum
  14. #12
    DK Veteran mahrkpat's Avatar
    Jun 2012
    Default OpenSPA v4.0.001 BETA 1 VU+ SOLO 2
    New OpenSPA v4.0.001 BETA 1
    Receptor: VU+ SOLO 2
    OpenEmbedded: OE-Alliance 2.4 (16-12-2014)
    Enigma2: OpenSPA (16-12-2014)
    Kernel: 3.13.5
    Drivers: 21-10-2014
    GCC: 4.9.1
    GStreamer: 1.4.4
    Observaciones:
    - Actualizamos a GStreamer 1.x (no est? operativo al 100%).
    Esta es una versi?n BETA de lo que ser? la 4.0 de OpenSPA y es muy probable que se encuentren bugs.
    Cualquier pantallazo verde que teng?is o bug que encontr?is reportadlo para poder solventar el problema.
    Por favor, cuando se reporten fallos de pantallazos verdes adjuntar el crashlog que se genera en /home/root/logs/ sino no sirve de nada el reporte.
    En cambio si encontr?is alg?n bug, a ser posible describir como hab?is reproducido ese bug. O sea los pasos a seguir para ver si podemos reproducir nosotros ese fallo y as? confirmarlo.
    Gracias.
    mit TsPanel beholfen, da Plugin-Feed noch down!!
    OpenSpa Team
    OpenSPA v4.0.001 BETA 1 VU+Solo2
  15. #13
    Jan 2012
    Sunny Morecambe
    the links no longer work
  16. #14
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    The image would be 3yrs old. The thread started for solo clone v2 and v3 and this is for a solo 2.
