Results 16 to 30 of 31
  1. #16
    super jumbe's Avatar
    Livingstone
    Ok pal I will try and get the latest bundle today after 9.00pm.
  2. #17
    Livingstone
    Please read instruction before installation.
    This is for VB-7000HD
    Like always I am not responsible for any damage to equipments of any kind.
    1. Unzip both files and install both files separately in the USB.
    2. You will have 2 options when asked for installation channel list or firmware.
    3. Reboot after installation DONE.
  3. #18
    Oct 2014
    Quote Originally Posted by super jumbe View Post
    Thank you very much my friend, I will check this.
  4. #19
    Oct 2014
    Quote Originally Posted by Mrdium View Post
    OK, I will give you my experience with this box, which I find with a poor quality, and I would not recommend it for a new buyer, unfortunately:
    - There is no website or official support
    - The box does not let me do any search as it is
    - When I upgraded (the first zip uploaded to this thread) and imported the channels list, it worked! But I had to use the 'Ebird1, Astra 2x' for my channels search, even though I am in the Nilesat position. It turns out that this is the only Sat I can search for, as it was uploaded in the channels imported.
    - When I reset the factory settings, back to the starts. No 'Antenna Setup' enabled, cannot search for channels, coz no sat is loaded to 'Antenna Setup'
    - When I upgraded the latest firmware uploaded by 'super jumbe', the screen blacked out. It turns out that the HDMI is not working. Had to use the AV output to downgrade to previous firmware, and import the old channels list to make it work again.
    Now I am happy (pretty much) that it is working with (hopefully) all the channels in Nilesat even though I used Ebird for search.
    The only thing I would appreciate to have, is a channels list from Nilessat (or ideally all satellites) so that I can import them to be able to search those satellites if needed. Not a great approach but seems to be the only option.
    I also have to avoid resetting to factory settings.
    Thank you in advance.
  5. #20
    Oct 2014
    Hi I am New Here But Just Wanted To know how to categorize channels from sat into asian,sports/ent etc. Thanks In Advance
  6. #21
    Oct 2014
    Quote Originally Posted by gettingther123 View Post
    I think the easiest way is to create Favorite groups. I think you can have more than 10 groups. So you can put each group fav group (Asian, sport etc..) and seek them when needed.
    I wonder though if you are experiencing the same problems that I did, or maybe just my box is faulty?
    Cheers.
  7. #22
    DK Veteran WOODWARD395's Avatar
    Manchester UK
    Quote Originally Posted by hodgey99 View Post
    hi can anyone help me getting a channel list for the vivabox looked everywhere but cant seem to find one anywhere thanx
    Try this should work To upload 'channel list', goto tools and choose upgrade only "Ch_list". nothing else or i am not taking the blame.
    Read here first before you delete all.
    Try here m8 hope it helps
    VIVABOX Receiver
  8. #23
    May 2018
    Hola, ha llegado a mis manos este receptor Vivabox vb-7000 hd y la verdad no se cómo empezar.
    Alguien que me pueda ayudar?
    Gracias y un saludo.
  9. #24
    May 2018
    [QUOTE = hazletree; 2111627] Aquí tienes este es el firmware y la lista de canales espero que ayude [/ QUOTE]
    Cómo puedo bajarme este firmware?
    Saludos.
  10. #25
    May 2018
    No hay nadie que me pueda ayudar?
    Saludos.
  11. The Following User Says Thank You to agustinazo For This Useful Post:
    Vivavoz (9th May, 2018)
  12. #26
    May 2018
    No se porqué no hay nadie que me impugne, <br> <br> <br> <br> <br> <br> <br> <br> <br> <br> Saludos.
  13. #27
    May 2018
    hello a friend has bought a receiver vivabox vb7000 hd
  14. #28
    May 2018
    Por qué no me puedo bajar este firmware?
    Saludos.
  15. #29
    May 2018
    Parece mentira de no no haya nadie para ayudar.
    ¿Porqué no responde nadie?
  16. #30
    May 2018
    Default Vivabox vb-7000 hd
    Buenas, algún Moderador, Administrador del foro me puede ayudar a descargarme este firm.
    Saludos.
