Results 1 to 15 of 27
    Apr 2012
    Wonderland
    Default freelander 0281010113 immo off
    i'm trying to make a immo off on a freelander year 2000 diesel with a bosch 0281010113 ecu msa 11
    immo decoding tell me to program both 93c46 eeprom and disconnect the immo box and splice togheter yellow and black wire
    where's immobox on this car!?!?!?
    please help me!
    ProTuner since 1999
    Shmortz's Avatar
    in the middle of nowhere
    I think in this car immo is incorporated in body control module, can't be removed separetly... just need to cut immo line and connect black/yellow wire from starter relay to GND...
  3. The Following User Says Thank You to Shmortz For This Useful Post:
    atomiczen (9th October, 2013)
    Apr 2012
    Wonderland
    Quote Originally Posted by Shmortz View Post
    hi shmortz, i have ear that it's possible to immo off this car switching the 2 dil for 50 seconds with ign on or removing one of the 93c46
    immo dec 3.2 tell me to program both 93c46 remove trasponder and splice togheter yellow and black wire, info isn't too clear....where are these yellow and black wires???
    i have to cut immo line from ecu or from body computer?
    antenna must be connected or not? there's 2 antenna on this car, one over the dash for the remote control, and one ring into the ignition switch
    where's starter relay?
    please help me because i become crazy with this car
    ProTuner since 1999
    Apr 2012
    Wonderland
    for who need i have found a solution here on forum
    remove the 93c46 near the yellow capacitors then cut pin 45 to the ecu
    tomorrow i'll test and report
    ProTuner since 1999
  6. The Following User Says Thank You to atomiczen For This Useful Post:
    KILL_THE_IMMO (4th May, 2015)
    Apr 2012
    Wonderland
    Quote Originally Posted by atomiczen View Post
    this solution don't work for me, car don't start
    ProTuner since 1999
  8. #6
    Apr 2012
    Wonderland
    problem solved, thanks to stoyanov and shmortz, problem was mine, i forgot to connect black/yellow wire from relay to ground
    dk forum is everytime the right solution!
    ProTuner since 1999
  9. The Following 4 Users Say Thank You to atomiczen For This Useful Post:
    DSAuto (10th June, 2016), lstuning (10th July, 2017), Serg1o (11th April, 2020), ssemmedo (18th November, 2014)
  10. #7
    Cepe Verde
    thanks for sharing. i?ll post result soonly.
  11. #8
    Cepe Verde
    please e need one more help. i need pinout to know pin 45 and i need to know the location of the starter relay. regards
  12. #9
    Jun 2016
  13. The Following 16 Users Say Thank You to Tonkov For This Useful Post:
    alclot (24th December, 2019), alejandrobr1995 (6th June, 2018), bangreno (21st November, 2018), danielif (6th October, 2023), dantetimoc (3rd May, 2023), daquima (24th June, 2023), gopelhu (28th January, 2021), H.Wessel (10th February, 2022), Jacob6969 (31st March, 2021), kronk92 (28th February, 2021), Rotor (23rd August, 2018), Serg1o (11th April, 2020), taythephoenix (27th September, 2022), Truan21 (8th April, 2021), vavrich (30th October, 2020), wolfoyo (13th December, 2017)
  14. #10
    Dec 2017
    i try this solution today
  15. #11
    Jun 2016
    Immo off ecu msa 11
    1.Remove the 93c46 near the yellow capacitors.
    2.Cut pin 45 to the ecu.
    3.Connect black/yellow wire from starter relay to ground.
  16. The Following 17 Users Say Thank You to Tonkov For This Useful Post:
    alejandrobr1995 (6th June, 2018), andrey3 (9th July, 2019), CaioW (23rd April, 2018), danielif (6th October, 2023), dantetimoc (3rd May, 2023), daquima (24th June, 2023), giani67 (4th September, 2020), gobe (12th June, 2019), H.Wessel (10th February, 2022), Jacob6969 (31st March, 2021), jmgameiro (20th March, 2022), marius7592 (16th December, 2021), tato10 (31st October, 2018), tellfaia (15th January, 2024), Truan21 (8th April, 2021), vavrich (30th October, 2020), wflseba (12th January, 2023)
  17. #12
    CaioW's Avatar
    Oct 2015
    Everywhere
    Quote Originally Posted by Tonkov View Post
    Immo off ecu msa 11
    Works like a charm.
    Thanks buddie
  18. The Following 2 Users Say Thank You to CaioW For This Useful Post:
    trinicolin (22nd March, 2021), vavrich (30th October, 2020)
  19. #13
    ugur028's Avatar
    May 2016
    giresun/turkıye
    ben yapamadım tam olarak epromu sökmelimiyim bana detaylı yaprdımcı olurmusunuz
  20. #14
    rafal's Avatar
    UK - PL
    Quote Originally Posted by ugur028 View Post
    this forum is using ONLY english language
    anyway from 2016 really not very helpfull
    need help
    now my goal is to buy xp-005
    who will help?
  21. The Following User Says Thank You to rafal For This Useful Post:
    brend (27th October, 2018)
  22. #15
    Feb 2016
    hello guys. i need help locating the black/yellow wire from starting relay. could you please tell me where is located? thank you
    +thanks if I helped you!
