Send me Bsi nummber i have many flash from P307 bsi JC you can write flash and bsi work . Problem isn?t in eeprom .Whit Psa tool from smok is easy job.Have FVDI tool for flash writing? If is you have win .
busaman (26th June, 2014), garagetech (24th January, 2015)
yes i agree hindsight is fantastic but i tried it before the problems were well known but now we know.
7.31sec@203.3mph
Hi friend.
Fvdi kill citroen c4 Picasso bsi
How to repair?
Bsi number : 96 640 59 08001
Please upload BSI flash.
this should be re-asked on the locksmith part of the forum under fvdi tech support - "gwee" can help you
I am a FUD
Before read or write BSI with FVDI charge the Battery on MAXIMUM and connect to another car with cable.
No problem after.
No work just for fvdi but it work for all programming.
DashProg (10th June, 2015), garagetech (24th January, 2015), racin-snake (10th October, 2014)
Stopped car = bad battery
Good tool for programmers: Multimeter DC voltage mode.
13v +.
Not charger, bad ,battery charger, AC noise.
WOW THIS CLONE WORKS !! tried and tested this afternoon so for me i think mine isn't a fake its clone but it does work
I kept tool on car for 40 mins to read JC BSI on a 2011 308 used battery support unit worked like a charm read pin via obd ( car was a write off so nothing to loose as engine ecu was crushed ) and needed a virgin one i cleared on the bench fitted
seems like every function i have tried personally has worked from adding keys to dashboard bin file etc ... seems scare stories were probably just pilot error in most cases maybe a shyte clone in other cases
Today is the Tomorrow you worried about yesterday ......Was it worth it ?
adam28 (2nd January, 2015), flyins (18th May, 2016), prochipper (16th August, 2016), teuton (26th October, 2014)
The BSI goes into boot mode if you unplug during this your as you found out ****ed .. unless you have a bad clone .. my one read 100% no problem and cars now running .. all via obd
it says 3. hours to do it when you start process if you shit yourself and unplug before its done about 40 mins as i said then youl leave BSI in boot mode it added key to a 207 this morning without a hitch either
busaman (16th October, 2014)
tell me did the wipers and lights run continuously on the read (mine did) and then nothing.
7.31sec@203.3mph
I have problem after trying reading pincode there is no ignition on !!!
How to repair bsi ???
