FVDI XTREME CAUTION!!! - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 65
  1. #31
    busaman's Avatar
    suffolk uk
    i think some tools (FVDI) are better than others also there are no instructions to tell you to wait 40mins (at least mine had none) there was also no caution about johnson controls bsi when connecting, and no reply when i mailed them, so i still think its wise to be careful when reading this particular BSI.
    7.31sec@203.3mph
  2. #32
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by busaman View Post
    Sounds like Russian roulette .
    Keep on trieing guys, i preffer good night rest.
  3. #33
    busaman's Avatar
    suffolk uk
    i haven't used mine since.
    7.31sec@203.3mph
  4. #34
    racin-snake's Avatar
    Jun 2009
    The time on parser was actually 3 hours 20 minutes IIRC but only took 40 mins in total ...also id think all software will be same ..
    Be a tad silly to think the Chinese would omit any part of the software just for a certain sellers wares to be honest ... i think its just been pilot error ! especially if you missed parser saying this it might be far more likely
    Lastly i have use mine many times since for key BSI and pin reading without problems ( touch wood ) 207 307 etc even replaced used module
    Might be a good idea to not use YOUR unit busaman as i think the Chinese maybe sent you a right DUD as mine seems to be quite stable fortunately...
    So just bought vag unit to try it and it seems stable for what i have tried so far only fault is minor with connection problems on some stuff but seem to work well after connection to other modules first IE read dash ecu etc then connect for read may help ..works for me
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
  5. The Following 2 Users Say Thank You to racin-snake For This Useful Post:
    busaman (1st January, 2015), prochipper (16th August, 2016)
  6. #35
    busaman's Avatar
    suffolk uk
    Quote Originally Posted by racin-snake View Post
    mine was one of the early ones so i think yes mine is a dud but i wont be experimenting with it just to find out and blow another one
    7.31sec@203.3mph
  7. The Following User Says Thank You to busaman For This Useful Post:
    racin-snake (2nd January, 2015)
  8. #36
    adam28's Avatar
    May 2009
    UK Essex
    Where did you get your FVDI mate? And would you risk on a Merc or BMW?
    NEVER GET SO BUSY MAKING A LIVING THAT YOU FORGET TO MAKE A LIFE......
  9. The Following User Says Thank You to adam28 For This Useful Post:
  10. #37
    Jun 2009
    mmmm don't think id risk Merc and testing AUTOHEX for BMW which is going OK ive ordered the vag and got renault pug and vauxhall software for now for FVDI seem to be ok though id prefer more time (more volume ) to say definitely Renault Pug and Opel ok tho bearing in mind i don't MILAGE ETC
    ALSO i bought it through a UK seller (importer ) il send his addy over skype if ya like mate
  11. The Following 2 Users Say Thank You to racin-snake For This Useful Post:
    adam28 (2nd January, 2015), clintezra (5th September, 2016)
  12. #38
    adam28's Avatar
    May 2009
    UK Essex
    OK cheers mate. That would be cool.
  13. #39
    busaman's Avatar
    suffolk uk
    ive just re -read the entire post do we have any pictures /documentation on the forum(i couldn't find any) of good/bad pcb,s.
    7.31sec@203.3mph
  14. #40
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    the good pcb has "AVDI" written on it mate
    I am a FUD
  15. #41
    busaman's Avatar
    suffolk uk
    Quote Originally Posted by obdsystems View Post
    7.31sec@203.3mph
  16. #42
    kevfield's Avatar
    uk
    If it takes 40 mins to read via obd wouldnt it be just easyer to remove bsi and read eeprom for PIN then you know its not going to go wrong , i know it might be a bit of a pig to get unit out but at least you know its not going to go wrong .....
    Thanks kev
  17. The Following 2 Users Say Thank You to kevfield For This Useful Post:
    garagetech (24th January, 2015), kelekele (24th January, 2015)
  18. #43
    DK Veteran kelekele's Avatar
    Sonta,Serbia
    Sad story from my good friend electronic expert.
    Kill bsi JC on peugeot 308 with fvdi.
    Car battery is being connected to charger,but in half writing program blocked and after long time wait,result is dead bsi .
    My advice is to remove bsi and read pin manualy with some programmer and not trust to seller that only have interest to sell this tool.
  19. The Following 2 Users Say Thank You to kelekele For This Useful Post:
    kidloco (28th November, 2018), ubistvo (25th October, 2018)
  20. #44
    Dessert
    Quote Originally Posted by kelekele View Post
    Well he is electronic expert so h? can restore bsi
    I already Said it before, bury smok and restore bsi when this happens.
    Wbr Adam.
  21. #45
    May 2014
    Hello Kelekele,
    When you say car battery was connected to charger, was it a battery support or just a charger? I wonder whether the charger could not keep the voltage stable enough.
