commando on eagle 1000
Results 1 to 5 of 5
    Oct 2008
    Default commando on eagle 1000
    got commando 14.7 on an eagle box trying to do auto bouquets but when scan finished get message transponder tsid 0822 is missing returning back to your old stored channels,anyone got any idea's what im doing wrong thanks for any help
    DK Veteran psats's Avatar
    Sep 2008
    Quote Originally Posted by jimbojimjay View Post
    have you added the new sat xml.
    http://www.digital-kaos.co.uk/forums...ml#post2121375
  3. The Following User Says Thank You to psats For This Useful Post:
    jimbojimjay (25th October, 2013)
    Oct 2008
    Quote Originally Posted by psats View Post
    thanks for your reply,ive tried putting the new sat xml on with dreamedit but keep getting problems starting to pull whats left of my hair out but thanks again for your help
    Sep 2008
    db edit wont transfere the sat xml unless you change the path that its located in 14.7
    its easier to transfere useing ftp prog
    there is updated img posted by AL with updates added
    http://www.digital-kaos.co.uk/forums...7/#post1852107
  6. The Following User Says Thank You to psats For This Useful Post:
    Old Git PaphosAL's Avatar
    Mar 2008
    a new satellites.xml in /var/etc folder requires the old one to be overwritten by the new one via FTP, and then a
    REBOOT
    is a MUST in order for the new one to be read into memory at restart, for use by the Update Scan phase of AutoBouquets...
    But better still, if you're on the latest 23/10/13 online update or updated image reflash, and your dm500 is connected to the web, then opt for Fast Mode in the AutoBouquets Wizard.
    This only takes 4 mins instead of 11 mins by using a UkCvs/TC download that's maintained up to date early every morning. So it circumvents the need for a 100% kosher satellites.xml and scanning, by going straight for the jugular vein, LOL!
    It's so good, that peeps whose dishes have shifted in the gale force winds in the past couple of days are using it as a 'Sat Finder' to realign their dish accurately!
    Not to mention that it now fits comfortably inside an AD break, leaving you still watching the ADs, even if GetEPG automapping spits it's dummy out finding a New or Renamed channel to map during the final 2 mins, LOL!
    Cheers- AL
  8. The Following User Says Thank You to PaphosAL For This Useful Post:
    jimbojimjay (31st October, 2013)
