video/resolution settings
Results 1 to 15 of 17
    Default video/resolution settings
    hi
    i am having a bit of trouble with my screen settings.
    the back grounds on tv are really bad , its hard to describe but the shading doesnt blend in and there is a visable difference from where it goes darker to lighter instead of being smooth.....does anyone understand what i mean and how to solve it on my vu duo running blackhole 2.0.3
    cheers
    ive messed about with my settings on tv and vu duo but still no luck
    Sep 2008
    try a different hdmi cable,yes i believe your trying to say picture is not crisp and clear,also does tv screen need a good clean as you would be surprised to see the crap removed from some.
    Quote Originally Posted by cactikid View Post
    hi cactikid
    i have a pic...not great but it shows what i mean but i dont know how to put it on here!
    edit...hold on i think i know
    ok see if this works
    on the left hand side can you see the shading is clearly in lines?
    Attachment 228386
    and on this one can you see the where the seat belt the shading is in lines?
    Attachment 228387
    Sep 2008
    neither of them work not valid.
    there is defo something wrong....have a look at this video and its poor quality but it show the picture going lighter and darker
    hmmmm
    they work when i click on them?
    Sep 2008
    yes i see it is not the best,check all your connections,i would still try a better hdmi cable to see if it improves or post what settings are on use on box and tv someone might spot something.
  10. The Following User Says Thank You to cactikid For This Useful Post:
    grogking (6th November, 2013)
  11. #10
    Sep 2008
    the links come up invalid attachment contact admin.
  12. #11
    the problem has just started in the last week.
    and there are so many settings i wouldnt know where to start...most of them are just default though
  13. #12
    hmmm ok after extensive googling i think its my tv and its false contouring.....i will start a thread elswhere!
  14. #13
    Sep 2008
    no mention of anything can be a difficult fix if you are even using a hdmi?
  15. #14
    yeah mate....i thought it was maybe a setting on my box but it seems not and i cant find any answers to sort it
  16. #15
    digicon's Avatar
    The first thing to look at is turn off all picture processing modes on your LCD/LED/Plasma such as Dynamic contrast, HDMI Black level, MPEG noise filter. Just so you know they could be labelled something different on your set.
    But this is a good starting point
