Page 8 of 16 FirstFirst ... 345678910111213 ... LastLast
Results 106 to 120 of 227
  1. #106
    Oct 2014
    ukraine
    full set for toyota push thanks and pm me
    https://drive.google.com/file/d/0B0npx9dIryLxYWMxZDVGUWxJUGM/view?usp=sharing
    89170-06380.CR1
    89170-06380A.CR1
    89170-06411.CR1
    89170-08090.CR1
    89170-08120.CR1
    89170-0D300.CR1
    89170-0E060.CR1
    89170-0E070.CR1
    89170-0E150.CR1
    89170-0T020.CR1
    89170-12670.CR1
    89170-12740.CR1
    89170-21110.CR1
    89170-21150.CR1
    89170-30A60.CR1
    89170-33570.CR1
    89170-35250.CR1
    89170-35251.CR1
    89170-47080.CR1
    89170-47081.CR1
    89170-47090.CR1
    89170-47100.CR1
    89170-47200.CR1
    89170-47280.CR1
    89170-48450.CR1
    89170-48460.CR1
    89170-48490.CR1
    89170-52G40.CR1
    89170-52G41.CR1
    89170-52J70.CR1
    89170-60450.CR1
    89170-60451.CR1
    89170-60630.CR1
    89170-60631.CR1
    89170-60750.CR1
    89170-60800.CR1
    89170-74080.CR1
    89170-75060.CR1
    89170-76020.CR1
  2. The Following 17 Users Say Thank You to anastudio1 For This Useful Post:
    amir_82013 (14th June, 2015), autokeypro (17th June, 2016), cougar89 (18th April, 2018), diagtech (14th July, 2017), dinar (24th January, 2021), garagetech (12th June, 2015), goga969 (25th September, 2016), Hack01 (13th June, 2016), lorena (20th June, 2015), lupu_sandu (18th July, 2015), lwood (13th June, 2015), mohamedkey (10th July, 2015), ngt5 (2nd July, 2016), PremierD (12th June, 2015), SergeyIg (1st December, 2015), soundnavigator (13th June, 2015), tech_cz (12th June, 2015)
  3. #107
    Oct 2014
    ukraine
    full set for subary push thanks and pm me
    https://drive.google.com/file/d/0B0n...ew?usp=sharing
    98221AJ030.CR1
    98221AJ050.CR1
    98221AJ07A.CR1
    98221AJ08A.CR1
    98221AJ09A.CR1
    98221AJ110.CR1
    98221AJ130.CR1
    98221AJ140.CR1
    98221AJ16A.CR1
    98221AJ16B.CR1
    98221AJ6A.CR1
    98221CA030.CR1
    98221CA090.CR1
    98221FG100.CR1
    98221FG110.CR1
    98221FG130.CR1
    98221FJ030.CR1
    98221FJ050.CR1
    98221FJ160.CR1
    98221FJ240.CR1
    98221FJ290.CR1
    98221FJ291.CR1
    98221SC090.CR1
    98221SC100.CR1
  4. The Following 14 Users Say Thank You to anastudio1 For This Useful Post:
    autokeypro (17th June, 2016), bassam (9th September, 2015), Darek90 (12th June, 2015), digimile (12th June, 2015), eleeinidis (12th November, 2015), garagetech (12th June, 2015), goga969 (25th September, 2016), lupu_sandu (18th July, 2015), lwood (13th June, 2015), ngt5 (2nd July, 2016), PremierD (12th June, 2015), SergeyIg (1st December, 2015), soundnavigator (13th June, 2015), tech_cz (12th June, 2015)
  5. #108
    Oct 2014
    ukraine
    """hi thanks for these files, may i ask how to use them im new to this programmer???"""
    it is simple
    open multiprog
    2 on help find srs module connection
    3 conect srs module to smok
    4 push butm chip ...push JTAG ...push RENESAS ..PUSH R5F1721/3/5 300KBFLS+EEPR(write)Crypto
    5 open file xxxxx.CR1 with #your srs unit
    6 push write
    it is done
  6. The Following User Says Thank You to anastudio1 For This Useful Post:
  7. #109
    Member cjohny's Avatar
    Feb 2014
    KAZAKHSTAN
    Hello! I make adapter for read write RENESAS single processor.
  8. The Following 5 Users Say Thank You to cjohny For This Useful Post:
    anastudio1 (15th June, 2015), datapage (10th September, 2015), garagetech (14th June, 2015), lorena (20th June, 2015), marco70 (23rd February, 2018)
  9. #110
    garagetech's Avatar
    Oct 2008
    Quote Originally Posted by cjohny View Post
    Which programer?
  10. #111
    lwood's Avatar
    city of angels
    Quote Originally Posted by garagetech View Post
    Which programer?
    looks like J-tag from smok
    DON'T JUST SAY PRESS IT.....
  11. #112
    Feb 2014
    KAZAKHSTAN
    Yes it SMOKE adapter for new ore unsolder processor without airbag ecu read-write .
  12. #113
    garagetech's Avatar
    Oct 2008
    Too many wires in the way need adaptor direct serial connection with Smok
  13. #114
    Oct 2013
    Hi Friends,
    I bought Smok from a reseller recently and am having problems. He hasn't responded after 3 days so I'm hoping someone can help.
    It's first time I'm programming an Infinion chip.
    Nissan Airbag module 98820 9am0a.
    Chip: Infineon xc2336b-40f
    Reading goes perfectly everytime. Writing is perfect except bytes f000-ffff.
    I tried different voltage to power the module (not chip) from 11-14v. I tried programming only the Fxxx block. Tried programming only 2 lines. There is no erase/blank function so I couldn't try. Tried writing 'ff' only or '00' only.
    But the values are still same old value. Is this fxxx block locked somehow?
    Any tip is appreciated.
  14. #115
    lwood's Avatar
    city of angels
    Quote Originally Posted by qubits View Post
    Hi Friends,
    are you connecting external 12v power??
  15. #116
    Oct 2013
    yes, external 12v at the external connector pins.
  16. #117
    lwood's Avatar
    city of angels
    post pictures of wires connected to modules
  17. #118
    Oct 2013
    Sorry I don't have the module anymore and didn't take a picture. It was connected just like in the picture of Smok manual. Do you think a bad connection will cause the programmer not to write a small block of the memory and not others?
    Smok support is basically no help.
  18. #119
    Feb 2014
    KAZAKHSTAN
    Do Nissan Sentra 2014 all ok foto attach
  19. The Following User Says Thank You to cjohny For This Useful Post:
    pire cemil (21st September, 2016)
  20. #120
    Oct 2014
    ukraine
    ANY ONE HELP WITH DIAGRAMS. HOW TO CONNECTIONS ALL WIRE FOR READ AND WRITE RENESAS BY SMOK J-TAG
    THIS WAY DIDNT WORK
    PLEASE PUT ON FORUM DIAGRAMS HOW TO CONNECTIONS ALL WIRE
  21. The Following User Says Thank You to anastudio1 For This Useful Post:
    gcesare21 (11th July, 2015)
