THIS IMAGE IS FOR SIM2 DM800
SE ONLY !
I have tweaked the latest pli 4 on my sim2 800SE clone and finally got it running sweet, have created a backup for any who wish to try it, when I first flashed it I noticed a dramatic increase in pic quality and the box seems nice an zippy due to the latest dmm drivers finally being cracked by sim2 team, I have done the following to this image -
removed -systemplugins fastscan+ osd3dsetup+ ppanel+ hdmicec+ module-rt2500usb-rt2800usb-rt73usb+ e2-helper+ sambaserver+ cablescan
removed wireless support as i only use hard wired , you can re-activate if you download modules from server in plugins menu
removed all language bar Inglish
added cooltv
added crossepg
added xmltvimport
added autobouquet
added nfi flash tool to create this backup
to install this image your box must be at ssl84a/b/c/d
obviously put box in "stop" mode
enter i-p from oled screen in web-browser address bar
flash file
sim2_800SE_SSL84D.nfi (do not boot box yet)
after sim2_800SE_SSL84D.nfi file has flashed, in address bar re-enter the i-p address (or open a 2nd window and enter i-p again)
flash 2nd file
OE-exp-dm800se-2013-11-09-15-22.nfi
boot box ,
backup has dhcp enabled and autobouquet is set for "North West Granada HD" area. user can change to personal choice
this backup will give a full epg if you configure your usb stick (which will automount on boot)
to setup epg do- menu- setup- crossepg- configure
configure crossepg to use your usb in "storage device"
in xmltv providers tick "rytec uk xmltv" only
save
then go to plugins and select "epg import"
choose a time suit yourself
click blue for sources and again select "rytec uk xmltv" only
ok/green
then to start the download/import hit yellow for manual
let it do it`s stuff and hopefully that will give you a full epg for 5 days, (you can change the 5 to a 7 if you want in "load long description up to x days" (see screenshot above)
think thats everythin, i have done a lot of experimenting and believe this is the best option for sim2 SE boxes available
enjoy
LINK -
sim2_800SE_SSL84D.nfi https://www.dropbox.com/s/mpdwzx2hm0...0SE_SSL84D.nfi -
OE-exp-dm800se-2013-11-09-15-22.nfi https://www.dropbox.com/s/vbarua5ld4...1-09-15-22.nfi
to display picons on your oled screen , download file "skin_user.xml.zip" and unzip it
download here
https://www.dropbox.com/s/t9vlsnn5e44tn8j/skin_user.zip
when uncompressed, it should be a dotXML file type , ftp file "skin_user.xml" to directory /etc/enigma2/skin_user.xml
download picons folder and unzip it, make a copy of it and rename the copy folder "picon_oled" (without quotes)
you should now have 2 folders, "picon" and "picon_oled" , ftp them both to media/usb
picons download here-
https://www.dropbox.com/s/xnc1x4ozi92oqup/picon.zip
reboot and you should now have picons displayed on box`s screen
