MS41 M52B28 swap to M50 manifold
    Apr 2013
    Default MS41 M52B28 swap to M50 manifold
    Hey Guys,
    i need your help again please.
    I want to remap a MS41 for the M50 intake and i need a clue which maps i have to change in detail. Maybe you can send me a good remaped file if it exists somewhere. The best would be a 256KB file.
    Thx in Advance
    Robert
    Basically what u have is more intake air. so you can inject more , and start injecting BTDC, and advance spark. You can use Vanos maps to make intake fuel mix start earlier and detonate the spark few degrees after BTDC. ALso you ll run more Lean, so make sure you add coresponding fuel and regulate lambda.
  3. The Following User Says Thank You to ominimicu For This Useful Post:
    Rockiii (10th November, 2013)
    Apr 2013
    Thanks so far.
    I think I understood.
    Is there anything out like a damos for this ECU?
    yes. also tuner pro has free definition becasue Damos are very difficult to modify
    Apr 2013
    Do you have the Xdf for tuner pro? I have only 256kb read and couldn't find a proper file on the web
    All maps are in there, i think i have them but it s for MS43...dunno where to get ms41
