Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
On mine update was done 2 days ago, remote made yesterday
Last few updates appear to be for "online only"
Just wonder if this is the route all the others will migrate to.
2010 Insignia
Astra J NB Multi Function wouldn't program, but old ATT-36-GM programmed OK.
Just to confirm kd900 doesn't support smart keys?
Has anyone done Dodge caliber 2008, I tried Chrysler remote menu 433mhz, the car starts but remote didn't work, any ideas what other model might work, I used universal remote, thanks this is %100 433mhz btw.
Need to generate remote OKA411TA/411T for Hyundai I800 (GRAND STAREX)2015.
Which remote to choose?
There are two remotes for Mini Cooper listed in KD Mobile app, 315MHz and 433 MHz. No FCC provided, so compatibility unknown. While programmed, both give some strange code. Does anyone know how to use that code? There's video on YT matching Mini 2006 fob, without using any codes, and apparently, they've created BMW remote in KD application at some reason. Any help?
bmw 3 button used in video is for older models,the 2 button remotes when you create it give you a code,you convert it and use it for remote programming
2004 Mini Cooper (US market) - is it also older remote? No codes needed? Thanks!
hello friends i need some help, i need generate renault 2 buttons pcf7946 433mhz like in picture, i generate on att-46, immo programs ok, but remote wont, work, i precode with vvdi key tool, precode with avdi, but remote still wont work, any ideas?
i am using mini kd blue cable, i attach pictures of att-46 i am using
thanks in advance
Work Smarter Not Harder
Have any body managed to generated & successfully programmed remote for Japan market Granvia or Grand Hiace ?
Just bought a Granvia (grey imported from Japan), which has only 1 remote key.
I tried many ways but still can not program another KD900 remote key to the vehicle
Please help ... (may need a special programming procedure???)KD900 remote.jpg
Hi guys
Did someone tried scirocco 2010?
202AD will work ?
Inviato dal mio HTC One utilizzando Tapatalk
